#16
Re: upper console light
yeah try shrinking them, if that doesn't work, ask a moderator...one of the guys should be able to help you.
![]() -2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*- |
#17
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
#18
Yeah goto a junkyard and just get one from a broken down Camaro and put it on your pocket and walk out!
good advice.
#20
I am so horny
#21
Re: Re: upper console light
wrong forum there, bud.
#23
I got the 211-2 light and is it the same type of light that's in the back hatch? Because I got the light to fit in the back hatch and it doesn't fit in the upper console. So am I missing the thing that holds the light in.
1984 Camaro 5.7L 350 700R4 Holley 650 Cfm Edelbrock Performer Intake-Manifold Crane Cams Duration @ .050": 204/214 Lift:420/442 Summit HEI Distributor Hedman Shorty Headers Hedman Y-pipe Dynomax Turbo cat-back NOS Decal VTEC Decal |
#24
Take a trip to the junkyard, it's cheap, and you will be able to see exactly what you are missing.
“When a whole nation is roaring Patriotism at the top of its voice, I am fain to explore the cleanness of its hands and the purity of its heart.” - Ralph Waldo Emerson |
#25
no offense but it would be easier if someone could just tell me........is it the same looking light socket thats in the back hatch?
#26
ok i got the lens for it and it dont come close to fitting.im definately missing something else since i cant post a picture here look at the picture here http://www.cardomain.com/ride/2092713 .........maybe this will help......i really need to know what im missing
1984 Camaro 5.7L 350 700R4 Holley 650 Cfm Edelbrock Performer Intake-Manifold Crane Cams Duration @ .050": 204/214 Lift:420/442 Summit HEI Distributor Hedman Shorty Headers Hedman Y-pipe Dynomax Turbo cat-back NOS Decal VTEC Decal Last edited by Jcrane88; 09-29-2005 at 07:23 PM. |
#27
link didnt work
87 firebird formula ws6 (currently has a old 78 305 with the following upgrades, including lots of miles and stock heads and internals....oops) crane cam cam specs performance valve springs and retainers, flowtech headers, 255 lph fuel pump, holley 600cfm carb, weiand single plane manifold, a healty diet. 14.90 1/4 mile....just wait for the 406 to be finished MY VIDEOS MY PICTURES -Tom |
#28
#29
i have an upper console that i put on, used to have just a dome light so i know the difference... you have to get a lens cover made specifically for an upper console, the simple dome light cover is a different shape than the upper console cover. and now the bulb for the third brake light is nowhere near the same as the dome light bulb. you are not missing anything for the bulb, just the bulb itself... go to advance or auto zone and tell the guys there you need a dome light bulb for whatever year camaro yours is. they'll get you the bulb and if you drive your car they might even test fit it just to make sure its the right size... i don't have the number on me right now... if you really think you need it (when you really don't need the number, just ask then for the bulb) the i suppose i could go and find it.
you are NOT missing anything, the buld goes inbetween those two prong... and you are missing an upper console dome light cover, which is different than a regular dome light cover so make sure you buy the right thing... try ebay you might find it there
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
#30
oh and the link still doesn't work
