Old 09-21-2005, 03:36 PM
Skugulgurk's Avatar
Skugulgurk Skugulgurk is offline
Make sure you have a wrench on both the banjo bolt and the fuel filter itself. We were lazy and decided not to do this when we replaced the fuel filter. We ended up bending the hell out of the outlet port. Also we found you don't have to depressurize the fuel system. When you remove the rubber hose towards the back of the filter just pinch it closed with some pliers and put a bolt into the end of the hose. To put it back on just use the pliers again. Good luck.
99' eclipse GS 420A !!!TURBO!!! Hahn kit installed. still on stock everything else, including exhaust.
I know it's taking FOREVER to finish the write up but the bands been taking off lately killing my free time. I've got some pictures posted though if you want to check it out.
www.angelfire.com/indie/kbracing
Old 09-21-2005, 08:06 PM
SLoe's Avatar
SLoe SLoe is offline
Re: Fuel Filter Change
You know no two people ever do anything the same way. So rip that somebitch off and see how that works for you. Either way doesn't really matter. The man asked how to depressurize the fuel rail, and that is how you do it.
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 09-21-2005, 08:34 PM
ted_ex's Avatar
ted_ex ted_ex is offline
Make sure you use flare wrenches when doing this. If it has been on for a while it is a pain in the freaking ass to get off and regular open end wrenches slip rather easily on the bolts, rounding it off nicely so it's almost impossible to get off. And it's always a good idea to relieve the fuel pressure, EZ is an idiot (he's my brother) so don't listen to him. Mine was so hard to get off that I almost let another person touch my car to get it off.
I'm>everything
Old 09-21-2005, 09:13 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Alright. I thought I had a day off this weekend, but of course I don't. Ill pick up a flare wrench and fuel filter this weekend. What sizes do I need?
Also, Ive seen cars with those stainless steel fuel lines. Mostly seen with nitrous. Are those any good? Worth doing? Thanks for all the help
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-22-2005, 01:03 PM
Skugulgurk's Avatar
I'm not sure how stringent the tracks are around you but, up here at Pacific Raceway(SIR) they won't let you get away with having any more than 10" of rubber hose on your fuel lines. The techs seem to be way more lenient with the slower import cars, But I would check with the tracks just to be sure, especially if you plan on going past the sportsman class. If you don't plan on going to the track, and you're going to stay normally aspirated I don't see why you would need to upgrade the fuel lines. The stock rubber ones should last forever.
Old 09-22-2005, 10:10 PM
ted_ex's Avatar
http://www.dsmtuners.com/forums/showthread.php?t=67761
Hopefully this should help.
I'm>everything
Old 09-25-2005, 06:43 PM
david-b's Avatar
Dave is THAT guy
OK, they say that the fuel filter is under the car by the fuel tank. Checked the Haynes (I found it!!) and it says underside the car, not in the engine compartment. I havent had time to check myself yet.
75 Monte Carlo
Old 09-26-2005, 03:12 AM
Skugulgurk's Avatar
The red circled thing is your fuel filter.
we had to block off the original line and run a new one to the regulator. I'll go more to detail on this with the turbo write up. Hope this helps.
