Old 08-22-2005, 10:55 PM
TheStang00's Avatar
TheStang00 TheStang00 is offline
Re: Re: Help Fast
Originally Posted by Pimpdady753
no i dont know why it melted, but that is the thing ive had this set up for like 3 months now and nothing has happend, you know what i mean. and how do i mesure the volts.
voltage meter... im sure you could find one at a hardware store
Old 08-22-2005, 11:17 PM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
It shouldn't make a big difference, but if you didnt already you are supposed to put di-electric grease between the module and the distributor. If that doesn't help, I would triple check your ignition box hookups. Also, what brand alternator are you using?
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 08-23-2005, 07:48 PM
Pimpdady753 Pimpdady753 is offline
Re: Help Fast
i dont know all i know there 3g alt. 200amp each. and i did not put the module in a shop did, so i dont think that is the problem. ive checked the ignition box so many times, it aint that.
Old 08-24-2005, 06:10 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: Help Fast
Sometimes when the module goes, the Primary Ignition Pickup in the distributor goes too, and that can cause your problem. Bad thing is you gotta pull the distributor to get to it all..
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 08-25-2005, 03:20 PM
Re: Help Fast
ok thanks
Old 08-26-2005, 07:05 AM
Re: Help Fast
is there any way that it could have fried my msd 6a Intion box,
Old 08-26-2005, 03:59 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Help Fast
By pass it and see.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-26-2005, 06:27 PM
Re: Help Fast
how would i do that.
Old 08-27-2005, 07:50 PM
Re: Help Fast
yeah there is no spark at all, any suggestions
