Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 08-14-2005, 09:07 PM
gtboiii11 gtboiii11 is offline
Send a message via AIM to gtboiii11
Re: Runs fine at idle, but seems to starve when the gas is hit
the truck will start with a bad pump!!! the pump is losing power and not pumping enough fuel pressure, this is exactly what happened to my truck, i would take it over 2000 rpm and the truck would stutter and stall out, due to the weak fuel pressure provided by the pump, th enegine is not getting the proper gas to stay running over 2000 rpms!!! forget the cpi !!!
  #17
Old 08-14-2005, 09:42 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Re: Runs fine at idle, but seems to starve when the gas is hit
Bullshit, it also can be caused by the fuel pressure regulator blowing fuel out its seal at higher fuel pressure.
Stop acting like the fuel pump is the only cause to a performance loss on a CPI engine.
Until we verify whether or not he is spraying fuel all over the inside of the upper plenum, you have no right to say I am friggin wrong.
You don't see me saying it is not the fuel pump do you.
You don't have enough information to say that my idea is wrong so shut the hell up.
kthx.
1995 Factory Blazer Service Manual for sale, PM if interested.
  #18
Old 08-15-2005, 01:15 PM
your just a punk ass kid who got your truck off your mommy and daddy and really dont know much about it. You have the same answer to every damn question, you either say ignition switch or cpi. And you are always certain your right.
  #19
Old 08-15-2005, 01:22 PM
Rick Norwood's Avatar
Rick Norwood Rick Norwood is offline
Big Tall Dumb Ass
BlazerLT, Pull the plug on this guy.
  #20
Old 08-15-2005, 01:25 PM
s10blazerman4x4's Avatar
s10blazerman4x4 s10blazerman4x4 is offline
Send a message via AIM to s10blazerman4x4
Re: Re: Re: Runs fine at idle, but seems to starve when the gas is hit
I agree Rick
1991 Chevy S-10 Blazer 5.7 V8 RIP
1999 Chevy Blazer 2dr 4.3
  #21
Old 08-15-2005, 01:33 PM
hazzzmattt hazzzmattt is offline
go with the fuel pump and youre gonna be right. the fuel pressure test is gonna tell the tale. that's the right move, dont guess. youre gonna see the fuel pressure start to drop off at about 1500 rpm then youre gonna slam a pump in it then its gonna be fixed.
  #22
Old 08-15-2005, 01:38 PM
Big Tall Dumb Ass
I've seen the same thing with a plugged fuel filter. Idle all day, but won't take the high RPM's When was the last time you changed your fuel filter?
  #23
Old 08-15-2005, 03:08 PM
calebcoe calebcoe is offline
I just changed the fuel filter the other day, the thing is that i could barely blow through it, so it really does make me wonder if it burnt out the pump. And as for you guys arguing, thanks for all the input, but you doods should just fight!
  #24
Old 08-15-2005, 03:25 PM
jsgold jsgold is offline
To put my two cents in, get a fuel pressure tester. Best tool you could have with these trucks. Check and see what it is doing. Don't cost a lot and I think you can rent them at Advance. Then while you are at it go ahead and check for CPI problems/injector problems by removing the Vortec plate and remove the round assy under it. Can't hurt. Also, one thing I don;t think anyone has mentioned, the TPS (throttle position sensor). If it is goofed up would that not cause problems with higher speeds?
I used to be indecisive, now I am not so sure.
  #25
Old 08-15-2005, 07:59 PM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
Without performing any tests it is imposisble to rule anything out as the cause.
But fuel pressure as well as fuel volume is critcal for this engine to run right. A 5 psi loss can cause this problem. You can also have the correct pressure but not enough volume of fuel. The pressure I believe should be around 55 psi and you should be able to fill up 1/2 od a soda can in 30 seconds time. That will tell you you have the correct pressure and volume.
Fuel filters and CPI's. Over the years I have done many CPI's in these trucks for the same complain as yours but a CPI is not the first thing I would try. CPI's are a costly item and that puts them dead last on my list of things to replace. Only when I run all the tests I can and have no bad results would I lean towards a CPI unit. Fuel filters would be one of the first because they don't cost alot and they are what traps all the dirt and sludge. Fuel filters can be installed wrong. They should have an arrow showing flow direction, installing the filter wrong would also cause a power loss.
Cats, TPS, O2, and coolant sensors can affect the engine. A partially plugged cat will give you decent idle but in the higher RPM's you would see a decrease in power and might mistake it for a trans slip. An O2 sensor that is skewed will affect fuel trim levels and it can add fuel or cut back fuel which would be felt more above idle. The TPS is an input to the computer which is used to determine fuel injector pulse along with the O2 and TPS.
I would first rule out the basics. The biggest mistake that techs make is to forget the basics and head right for the CPI unit only to find out after replacing it they still have the same problem. I will agree with BlazerLT 90% of the time their is a problem with the CPI, they are prone to failure but as a tech I only have one try to get it right. Since there realy is no test to rule out the CPI you need to rule out what you can and then you can look at the CPI as your problem.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
  #26
Old 08-15-2005, 08:05 PM
BlazerLT's Avatar
AF -Advisor
Because you know why, more often than not I AM right. If you have a problem with MY advice, that is fine, but don't cut up my help when you don't even know if I am wrong.
This is your first and final warning about the insults, I never insulted you.
  #27
Old 08-15-2005, 09:05 PM
first and final warning about insults? what are you going to do come to florida and do something? i think not, but you are the one who said that i was wrong when I GUARANTEE that i am right on this one, i have had every problem in the book with my truck, and with his described syptoms it is 100 percent the fuel pump, ill put my truck on it!!!
  #28
Old 08-15-2005, 09:07 PM
why waste 300 dollars of the guys money on a cpi when it is the pump for 70 dollars
  #29
Old 08-15-2005, 09:10 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
This thread served its purpose. If the thread starter has anymore questions feel free to PM a moderator or start a new thread. Lets all try to get along please, no insults is not too much to ask.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Closed Thread
