Old 08-03-2005, 01:10 AM
PALLADIN72 PALLADIN72 is offline
Send a message via AIM to PALLADIN72
Re: Re: Stalling issue- Driving me crazy
Originally Posted by BlazerLT
Does the fuel pump hum when you try to restart it?
Ever replaced the fuel filter?
First thing we did was replace filter & pump. I've driven it by necessity some 300 miles since replacing pump.
Replaced:
Fuel Filter
Fuel Pump
ECT Sensor
IAC
Have not replaced TPS, but did about 1.5 years ago. Symptoms much different. Does EGR give this type of symptom? Can I test it somehow? I'm tired of throwing $$ at parts. Can't afford much more. I'm afraid of what starter fluid is doing to engine, even with just two quick shots.
Old 08-03-2005, 01:47 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
EGR could do it.
Remove it, clean it and reinstall it with a new EGR gasket.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-03-2005, 01:22 PM
EGR could do it.
How do I clean EGR? I saw that I cant use solvent. Is there something special?
Old 08-03-2005, 02:48 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: Re: Stalling issue- Driving me crazy
Carb cleaner works good to clean your EGR. However i still think you need to check your battery. Low battery voltage can cause these kind or troubles.
Old 08-03-2005, 03:20 PM
Re: Re: Re: Re: Stalling issue- Driving me crazy
Checked battery, reads 13.8 v
Old 08-03-2005, 03:32 PM
BlazerLT's Avatar
AF -Advisor
Also use a new EGR gasket when you reinstall it.
Old 08-03-2005, 04:06 PM
Re: Re: Re: Re: Re: Stalling issue- Driving me crazy
Working on it now. I mentioned it I think before, but not sure of significance. It starts in morning, first thing. It wont stall untill it warms up to about 180. Is this significant?
Old 08-03-2005, 04:37 PM
gtboiii11 gtboiii11 is offline
Send a message via AIM to gtboiii11
alright buddy i am having the exact same problem as you, i finally gave up and had to drop it off to a serious garage, when mine warms up maybe after being driven 3-5 miles, you give it gas and u really cant even hear the engine then it may just flash check guages and the blazer will shit itself off, i have replaced fuel filter, pump, sending unit tank, done a tune up, cleaned egr,cleaned inside the plenum, replaced tps and o2 sensors and none of this worked, making me have to take it to the garage, they told me that it was my control module, which makes perfect sense, figuring that after it warms if the coil is not seeing a spark it will not allow it to run properly or even at all, same problem happened it my boat. So i told them to go ahead and replace it, the part is 94 dollars and they are only charging me 12 dollars for labor figuring it is a very quick job. I will tell you how this works out tommorow, but i am pretty positive after replacing all of this that this has to be the problem, do your symtoms sound the same as mine?
Old 08-03-2005, 04:53 PM
Symtoms are almost the same, except that mine runs great until I come to a stop. If I leave my foot on the gas it will stay going. It accelorates just fine. I'll take a look at it and let you know.
Old 08-03-2005, 10:41 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Re: Re: Stalling issue- Driving me crazy
Sounds like it doesn't like going to closed loop.
Check your ECM grounds.
Old 08-04-2005, 12:19 PM
Austin8214's Avatar
is that with the truck running? Also have someone check the voltage as you are starting the truck if voltage drops below 11 then you have a problem.
Old 08-04-2005, 01:09 PM
the battery wont even cause signifigant problems if a lil undercharged at 11.6 or w/e that should be fine
Old 08-04-2005, 02:27 PM
13.8 with the truck running.
Just finished cleaning EGR. Replaced gasket as well. Same result. Can it be a heat issue? Gage says it is about 220, but campartment feels hotter. Could this be related? Radiator not bubling over, but feels hotter than a lot of cars. Seems like it has always been this way, but now I'm grasping at straws.
Old 08-04-2005, 11:12 PM
BlazerLT's Avatar
AF -Advisor
If the alternator is not changing it you bet your ass it will cause problems.
Old 08-04-2005, 11:14 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Re: Re: Re: Stalling issue- Driving me crazy
Something is wrong then, the alternator and battery should be at 14.4+ when running.
