#16
Re: question about posi and my driveshaft
The new rear would still attach to the rear U-joint and yes unless the dimensions changed, it would be the same size shaft.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
#17
Re: Re: question about posi and my driveshaft
All Throttle, No Bottle! Torque Makes You Go... FAST! Horsepower Is For Braggin Rights. Money talks, But all mine ever says is Goodbye ~Viper ![]() "twospirts" / "TS" - Definition: Obsolete |
#18
No biggie, if you want one let me know. If not, no big deal. I only get them in when someone needs them, so I am not trying to sell off a supply of them I have.
#19
Sounds sweet. Yeah my driveshaft is rusty....darn....Let me get some cash together and ill let you know. I gotta pay for school soon so Ill have to figure something out. Its a fairly loud whine. I thought it was my bearings in the front but then I replaced them when I did the brake job. Its most loud when i take my foot off the gas and slow down. Its not extremely loud or anything but it is there. Could be the transmission for all I know. I should just go ahead and have my tranny fluid changed.
Thats something else to ask....Someone told me not to flush the tranny just change the fluid. This was at a car show and there was a lot going on so I didnt get to ask why. I also wanted to change my differential oil. Is that a simple non huge mess making and time consuming (less than 5 hours) kinda ordeal? Ive never messed with a rear end before. Maybe it will get rid of the whine.
92 z28 camaro 5.7 TPI current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
#20
Whining from a rearend is usually a sign that the differential isnt setup properly. Some gearsets are just noisy but when they are setup right, they usually sound like a factory rearend.
#21
not to be an a$$ for trying to take busniess away from you FormulaLT1 but i got my aluminum driveshaft for 50.00, just look around the internet or a 4th gen site and get a used one from them.50 is pretty cheap for a aluminum driveshaft.i seen them any where from 30-100 most of the time.
1991 RS 305 T.B.I. 700-R4
#22
Thats a great deal and by all means. If you can get them that cheap jump on them. I never got one that cheap.
Is it the 1le or ls1?
#23
perverts all talking about shafts and crap...
same driveshaft for z28 is for the 6er?
![]() ![]() ![]() www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR |
#24
The 6's and v8's use the same length shaft. (you may have to swap the yokes but I doubt it).
#25
mine came from an ls1...is the 1le a 3inch like the ls1
#26
No, the 1le is 2.5 inches and weights 12.2 - 12.5 lbs. So you got the much better of the 2. Also the LS1 is rated to handle more torque.. You got a sweet deal.
#27
i was checking out your e-bay post and it says "98-02 LS1 F-body with either 3.23 or 3.42" what are those numbers at the end? 3.23 & 3.42?
#28
Those are gear ratio's. LS1 f-body's with 2.73 gears or the rare 2.93 gears had steel unbalanced shafts. Only the 3.23 geared Auto's and 3.42 geared Manuals got the aluminum balanced shafts.
#29
so if you have a 98 - 02 LS1 Fbody then you already have the aluminum driveshaft?
#30
No, not always. If you have a Auto without the performance rear axle package. You would have had 2.73's or 2.93's and those cars got steel 16 lb unbalanced driveshafts.
