Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 07-27-2001, 09:55 PM
kenchan's Avatar
kenchan kenchan is offline
i took off the rocker panel and was able to get to the ECU, but I could NOT find that screw with a LED. do I need to take the ECU off the braket to find this? I looked all around it with my fingers on the other side where I could reach, but could not find any srew hole opening. did find one 'hole' that was covered in clear faceplate taping...is that where the dial is? if so, breaking the seal would probably void my warranty.
where is that reset screw on a 2001 ECU????????!
thanx. the servie light is still on.
1998 Prelude SS - TEIN HA with upper pillows, SSR Integrals 17x7 with SP8000 (215/45), GReddy Evo catback, Iceman Comp Intake, DC Sports header, Apexi VAFC, ZEX 55 shot with bottle heater, NOS blanket, Factory Body Kit, Spoon F/R tower bars, JDM Foglamps, Carbon Fiber trim, Razo pedals &knobs, Fiamm Dual air horn
Future Mods: Lighten car, 2nd 10lbs nitrous bottle would be nice too.
2001 G20 P11 AT- TEIN NA, TRM Snipers 17x7 with Potenza RE910 (215/45), Arospeed Dual-outlet Muffler, K&N Drop-in Airfilter, WW Front Lip, Nakamichi MB75 1DIN 6CD Changer/Receiver, FIAMM Dual Air horns, Levoc Pedals, PIAA (H4 Superwhite H3 Ion Crystal, 168 SuperWhite)
2002 WRX MT- TEIN HA's with upper pillow mounts, 1000Miglia HT3 17x7 with sumitomo HTR+ 225/45/17, painted side skirts, Cusco front & rear strut bar, Whiteline rear swaybar, aluminum endlinks, Blitz NUR Catback, HKS seq. BOV, factory front lip, rear valance, Kartboy short shifter and bushings.
Future mods: dressup wheels with Potenza S03 225/45/17 tires, TurboXS UTec, maybe an uppipe. by then, it'll be fast enough.
fiamm dual air horns.
Old 07-30-2001, 09:02 PM
kenchan's Avatar
Dudes!!! I was driving out to work this morning and noticed that the service engine light went off automatically!!! made my day. hehehehe... sad...shouldn't have happened in the first place.
Old 07-30-2001, 09:09 PM
primera man's Avatar
"P-Man"
Its al in the way ya hold ya tongue
I bet its one less worry now for you.
Best of luck
View All My Models Here.
Old 07-31-2001, 09:10 PM
kenchan's Avatar
hehehe, yeh, I am very relieved. hehehe. gonna get the car's oil changed this week and get the wheels aligned I guess.
feels good driving around this car again. :sun:
Old 08-01-2001, 12:33 PM
Chavez Chavez is offline
Try This
Sup man! Mine came on the 2nd day I had it. Brought it in to the dealership and said that when they rustproofed the car, it must have hit some kind of sensor. I got my car back 15 mins. later with the light off. Not sure but you might have the same problem. Sensor just needs to be reset. See u around!
Old 08-01-2001, 02:28 PM
geoff200 geoff200 is offline
Kenchan,
You may not have a screw and LED on your ECU. Mine is a UK Primera and I do not have this arrangement for re-setting the ECU.
On my car the ECU is reset by bridging two contacts. The contacts are in a plastic block located just below the fuzes. You gain access by removing the cover in the dash.
It is incredibly simple to do - takes about 30 secs. First bridge the contacts and hold for at least 2secs, the codes are revealed by the engine light flashing at you. First long flashes - count them, then short flashes - count them. Put the two numbers together and you have your code e.g. 55 means no problems. when you are finished reading the codes bridge the connectors again to put the ECU back to normal mode. The ECU has then been reset.
Reset your ECU after every engine type mod.
Old 08-02-2001, 11:26 AM
kenchan's Avatar
thanx dudes. :)
thanx, I'll give it a shot next time. I gotta feeling that the super unleaded I fed in it made the light to come on. before, I was using 87octane, I switched to 93octane just to see if the sulfer smell would go away....and it did! but the light came on
I filled it up again with 93 octane to see what happens. next time, I'm gonna feed it 89 octane...if the light comes on again, then I know it's just too sensitive to the fuel for emissions issues. so, no prob.
got the oil changed today, but did not have time to get the wheel alignment done. btw, how much do wheel alignment-only cost these days? $50? (usa)
Old 08-04-2001, 08:37 PM
1PNYBOY 1PNYBOY is offline
Kenchan,
I am a service advisor for an Infiniti dealer here in South Florida. There is a technical service bulletin(TSB) for that sulfur odor that you are talking about. Take it in and they will program your ECM with their Consult. The 93 octane will help with the sulfur smell also, but it did not cause your check engine light to come on. More than likely you may have accidently moved or knocked the air temperature sensor loose when you removed the air box. After a few starts if the ECM see's that there is no problem with the sensor, it will shut the light off. But, you should probably take it in and have them clear it from the memory. They will clear it at the same time the perform the TSB for the sulfur odor. Hope this helps.
P.S. You can get the alignment done under warranty at the dealer just tell them that the car is pulling to the right. If the carhas less than 12000 miles and is under a year old, than they have to do it under warranty. Just make sure you get a print out from their alignment machine.
Old 08-05-2001, 04:54 PM
kenchan's Avatar
thanx
1pnyboy- thanx for the info. I'll put some 87octane next time and when the smell comes back. I'll take it in. kind of a waste using 93 octane fuel when the engine is suppose to run on 87....
Old 08-12-2001, 02:11 AM
aluke000 aluke000 is offline
Back to the earlier discussion regaining the engine light, I have the same situation. I have just installed a Weapon R intake and V2 filter and I have the Check Engine Light on. I checked the diagnostic code and it comes up as 1 long and 4 short flashes, which is the Vehicle Speed Sensor? Anyone know why this would be?
Old 08-13-2001, 01:21 AM
kenchan's Avatar
donno, but if you have a hunch wat the cause might be and know that its not gonna damage the engine, then drive around on it as is for about 10 days. light should come off. otherwise take it to the dealer beforehand, up to you.
Old 08-13-2001, 11:33 PM
kenchan's Avatar
hummm... my P11 was starting to give off that sulfer smell even with the premium, so made an appointment to take the car in this week. service guy told me that it's a quick re-program ...should take no more than 1hour max. so wish me luck.
btw, thanks for your help regarding the technical service bulletin issues on the sulfer smell.
Old 08-14-2001, 07:19 AM
b-b00gie's Avatar
b-b00gie b-b00gie is offline
Banned
Send a message via AIM to b-b00gie
Actually, I read somewhere that its the higher octane fuels that cause the sulfur smell..
Apparently with the higher octane fuel there is some un-burned fuel which enters the cat causing the smell.
Old 08-15-2001, 10:32 PM
kenchan's Avatar
its freakin weird. when the engine is cold it doesn't make that smell...after it's warm and ideling it just stinks up the whole place. I even tap on the gas when some asshole stops so darn close to my tail at the light. hahaha, there's yellowstone for ya.
Old 08-16-2001, 06:51 PM
kenchan's Avatar
hi guys, got the ECM reprogrammed this morning. so far so good, absolutely no sulfer smell. will keep you posted. right now using shell 87octane.
