Old 07-16-2005, 03:27 AM
91civicDXdude's Avatar
Re: When i lowered my car the crankshaft pulley hits tie rod!!!????
FYI, that is not the tie rod, it is called "radius rod". I've seen that happen a couple of times and most often it is caused by worn or too soft motor mounts.
Old 07-18-2005, 03:49 AM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
The motor mounts are place racing, the enine really doesnt jerk alot or anything, maybe its not that noticeable i guess.
PIX CAN BE FOUND HERE
http://hometown.aol.com/twyztidmind/projecthatch.html
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 07-18-2005, 10:02 AM
2CrX's Avatar
2CrX 2CrX is offline
What parts did you use from the integra for suspension?
Old 07-18-2005, 04:58 PM
O, it was rubbing before i ever did the integra front brake conversion. But i used the whole Knuckle assembly, know i just have to get a camber kit to fix the possitive camber
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 07-18-2005, 05:24 PM
Can i bend the rod in any way without messing up anything?
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 07-18-2005, 08:15 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
no, dont do that. look into it more and you'll find out whats really wrong.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
