Old 08-14-2005, 08:30 AM
Sunliner Sunliner is offline
It almost always sets a code 1870 (component slip) on my '97.
I can pull over, turn the ignition off for a few seconds & start again and the truck will shift fine, though the light stays on for a few days.
For reference:
2006 TrailBlazer LS
I6 2wd
Automatic trans
~72 k miles
I miss my '97 Blazer...
Old 11-03-2005, 02:43 PM
denisew's Avatar
denisew denisew is offline
Re: Tranny Problem..please Help!!
sad news...
I finally took the truck in to the trans shop. After going over all the options, I finally gave permission for them to drop the trans. Turns out, yes it is the valve body, but also the clutches were cooked, and 2 check balls were stuck. You could see the indent on the plate. They said it still ran well, considering everything they found. They are rebuilding it, updating w/sonnax, this afternoon. $1200. I guess I knew it was coming. Hopefully this is one less headache for us now. Just about anything else that goes wrong, we can do ourseves. But trannys are a no-no.
And, while it was up on the rack, I noticed a fresh oil leak.......I hope it's not where it appears to be..the oil pan!
Old 11-03-2005, 11:00 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
This is exactly what happens to the tranny when you have a bad TCC regulator valve that is worn, which is almost always the problem with these valve bodies. This is the common sonnax part everyone talks about. The part is not that expensive, and is rather easy to install if you have the specific reamer that is required. The reamer though is expensive (Around $ 150.00)
You usually will get the common P1870 code, indicating trans component slipping, sending max line pressure to the transmission, giving you the hard 1-2, and basically slowly, yet surely destroying your transmission. Anyone who drives with the P1870 code and does nothing about it, should be prepared to rebuild their transmission, becuase it will eventually fail.
The TCC PWM solonoid can cause a harsh 1-2 shift also, but this can be checked with a scanner while test driving the truck. The scanner will verify if the PWM is within range. If its not within range, the PWM would have to be replaced. If its sending proper voltage values to the scanner, then the next thing to look at(assuming all other readings from the transmission are within spec. and no service engine light is on, is to look at the TCC valve regulator (the sonnax part).
The check balls are common, Trans-Go makes a thicker valve body plate that resists the common problem of check balls going through the valve body plate. The Trans-Go also resists the rusting, which is common on these plates also.
The clutches they are referring to usually are the 3-4 clutches. They are a very common problem, and burn up as a result of the TCC regulator wearing out in the valve body. A very advisable thing to do(especially if you plan on keeping it or if you do a lot of towing), is to upgrade the weak 3-4 clutches to something like the Raybestos Z-Pack, or Alto 9-clutch pack. They can take the higher stress in these trannies, and last a lot longer than OEM. That being said, the O.E. 3-4 clutch pack has been redesigned to take more stress than the previous ones used. In my opinion, I still don't think they are good enough.
Another good thing to do is to just replace the sun gear shell with a stronger, better built unit. Something like "the beast", or something stronger. This is a very weak point in the 4L60e.
Ask and see what they replace, and what they leave in the tranny. Some builders will replace bushings, bearings, all clutches and stuff, others will just replace whats broken. This last option is not a full rebuild, just a fix(hopefully). Either way, I hope this helps give you an idea as to whats going on.
Also, here is a link for the Sonnax TCC regulator.
http://www.transmissionspecialty.com...-Combo(rb).pdf
Old 11-05-2005, 07:38 PM
denisew's Avatar
blazes9395
thanks for all the info.
I checked into what was being replaced. They brought me into the back room where they rebuild, my parts had just came in. They are replacing everything. I got all the old clutches and stuff from them. Actually, I got the truck back late yesterday afternoon. Drove it for a short time. Seemed o.k. Today I had to take the kids somewhere, got on a mainstreet out of town..Now it seems to be slipping from 1st into 2nd. I took it back to them, just as they were closing. They are going to have the builder come in on Sunday and look at it. I don't know what's wrong with it now. Even before they rebuilt it, it NEVER slipped like this. I hope it's nothing serious, my husband almost blew a blood vessel when he felt it slip like that, especially after shelling out $1200 bux! Oh well, I guess I'll find out tomorrow...stay tuned.
98 Blazer LS-2WD
4.3 vortec-W vin
Old 11-06-2005, 12:01 AM
sarkkjos sarkkjos is offline
Hey, my 96 felt like it was slippin alittle at highway speeds (pulsing?) My 95 did th same thing:it was low on fluid. i checked the fluid and did the new filter/gasket option, and now the original problem seems better, but the check engine light is now on, the gear indicator light PRNODD21 doesn';t show up at all, and it seems as though it starts out in 1st or maybe 2nd gear. i can't spin the tires in my gravel driveway, unless i manually kick er down to 1 or 2. Please help me figure out what i screwed up. thanks
