Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 07-27-2005, 06:58 AM
jimmytroanoke jimmytroanoke is offline
Re: Re: Re: Runs Like in 7 Cilinders
Originally Posted by jimmytroanoke
This engine is famous for clogged EGR Passages in the intake. Remove the elbow that your throttle body is attached to from the intake and look under the gasket - there is a horseshoe shaped passage there that is full of guck. shopvac the guck out and push a rod down the passages to the egr valve. this is so common on these engines that the EGR valve itself is rarely the culprit.
From above post!
2001 Grand Prix SE 3.1 - Someone elses problem now!
95 Grand Marquis - Will outlive all of them!
97 F-150
2004 Toyota Avalon
Old 07-27-2005, 12:42 PM
jesus058 jesus058 is offline
Send a message via Yahoo to jesus058
Originally Posted by full_flex
Hi, I think I'm having the same problem. Can someone explain where and what I'm supposed to be replacing/cleaning? Any detail or information on how to proceed would be very appreciated. Thanks in advance.
If it's the EGR. Remove the air filter elbow
1.- Disconect TPS and Throttle linkage from the body.
2.- Disconect the vacuum hose from EGR Valve.
3.- There are 2 bolts to unscrew holding a plate for the EGR sensor and control valve.
4.- There are 4 bolts to unscrew holding the throttle elbow against the intake manifold.
5.- Lift the elbow straigt up, watch the gasket for damage.
6.- There is a horse shoe shape passage with 3 oppenings that gets clogged with smoke.
7.- Clean the passage with a small screw driver and choke cleaner.
(Use a rag to block the intake).
8.- Use a small hose to creat vacuum on the EGR and get it open; this will help you drain de choke cleaner, and check the EGR at the same time. If the cleaner won't drain the EGR is damaged.
9.- When you feel everything it's clean and OK, Reverse for installation.
To change the EGR if it's bad, you must disconet the pipe from the exhaust and 2 bolts from the EGR to the intake manifold.
Old 07-27-2005, 04:45 PM
widebodyscotty widebodyscotty is offline
I'd like to do the same job, but I just came out from under the car and I can't even FIND the EGR! Is this supposed to be done from the top of the engine??? Can someone please explain how to get access to the EGR valve???
Also, I would first like to clean the MAF sensor. Got stuck on step 1. It's secured in with these "tamper-proof" torx screws. I checked 3 different strores in town, no-one has even heard of these! Anyone know where I can get a #20?
Thanks for any help guys!
WBS
Old 07-27-2005, 05:16 PM
WBS
Yes, it is done from the top. The egr is bolted to the back of the intake. You will have to move some other small stuff to get to it. It is a little like building a ship in a bottle blindfolded. If you look toward the back of your intake you will see the elbow you need to remove. Unless you are sure your egr is bad leave it alone. The clogs happen under the elbow usually
97 F-150
2004 Toyota Avalon
Old 07-27-2005, 05:26 PM
I have not clean my MAF sensor yet, I think you can spray it with choke cleaner also.
To you can get to the EGR both top and bottom.
The job that I decribed you is done from the Top.
To get to the EGR from the bottom you must raised the car on the passanger side, loose 1 of the 2 connectors on the exhaust pipe and the 2 bolts that hold the EGR to the Intake manifold.
Good luck !!!!!!!!!!
Old 07-27-2005, 09:37 PM
Re: Re: Re: Re: Runs Like in 7 Cilinders
Thanks, I'll give it a go in the morning.
WBS
Old 07-28-2005, 02:45 PM
thebigtexan thebigtexan is offline
Same Issue on a 2000 model
Would the same issue occur on a 2000 model? I get sputtering and jerking from 40 to about 55 miles per hour.
Old 07-28-2005, 02:55 PM
Re: Same Issue on a 2000 model
If you feel like the transmition goes from OD to 3rd back and fort.
There is a position sensor installed on the shift linkage that tells the computer the actual shift position. When it fails tent to do the up and down shifting.
Have a Trans. chop check it.
I hope this helps you.
Old 07-28-2005, 04:06 PM
How expensive is the replacement of the transmission sensor?
Old 07-28-2005, 04:35 PM
I do not know how mutch will cost, I got mine as a freebe from a transmition shop where a got my wife's Winstar fixed.
Old 07-28-2005, 04:36 PM
I don't think will cost more than $50
Old 07-28-2005, 05:03 PM
Unhappy Same Issue on a 2000 model
I talked to a transmission guy and he thought it could be 1 of 2 things: plug wires or the torque converter. Thoughts?
Old 07-28-2005, 05:11 PM
Kool
Wires are around $85 bucks
Torque a lot more.
Question: Have you check the codes?
Old 07-28-2005, 05:16 PM
Angry Re: Re: Runs Like in 7 Cilinders
No, he wants to drive it in the morning. He claims that the torque convertor is also a common problem.
Old 07-28-2005, 05:17 PM
Exclamation Re: Re: Runs Like in 7 Cilinders
Can some local parts stores pull codes?
