Old 06-06-2005, 01:09 PM
kita23 kita23 is offline
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Free mod
Originally Posted by kita23
this is already when the car is warm, running more than fifteen minutes. this week when i have time im going o install a 180 tstat. ill let everyone know how it went. thank you for all your help
Ok, i did the tstat change today on a cold engine. When i pulled the old tstat out of the housing is when i lost some coolant, i pulled the tstat out n then the coolant ran fer a few seconds n stopped. I'm takeing this is normal??? I put the new one in and followed all directions. So far no porblems but I havent ran it much cause of severe thuderstorms weve been getting the past few days. I won't know if it worked until i get stuck in traffic on a hot and humid day. Will post results.
Old 06-06-2005, 01:42 PM
adblink182 adblink182 is offline
Re: Free mod
how often should a flush be preformed?
Old 06-06-2005, 02:01 PM
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Free mod
I took it for a drive finally and made purpose to get stuck in traffic. it was running around 150 n then the traffic. In the traffic it GRADUALLY went to 210 n hovered there but as soon as air hit it it went right back down. I bled the air out of the system but as soon as the hissing stopped that was it, no coolant came out. I am thinking there is still air in the system somewhere. Is there any other bleed valve and how to use it
Old 06-06-2005, 02:23 PM
ericvrose ericvrose is offline
Was the engine running when you bled the air out? It should be warmed up and running.
Old 06-06-2005, 08:42 PM
Re: Free mod
It was warmed up but it wasn't running. I thought you had to turn it off. anyways, it seems to be working fine now. i run a cool 150 on the high and on city streets 180. thank you for all your help
Old 06-06-2005, 09:44 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Free mod
OK, here's how to change a Tstat.
http://www.pfyc.com/supportfiles/tstat/tstat.htm
Now, check to make sure your fan is starting.
