Old 06-01-2005, 12:55 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
Originally Posted by kustomkid54
Boy, I'm glad I didn't write that. 11.93 is pretty good time.
Speaking of parts? When are you going to change your list? I know, your waiting for someone to come down to TX, and blow their doors off, right?
11.93? Is that real world, CAD system, or on a dyno?
Oh, you mean the 3.25 SC pulley and Autolites? Lets see how I do at the strip this Saturday first. Anyone's welcome to come to West Texas and take us on (ThunderAlley Dragstrip - IHRA) but they better be tuned for over 4000 feet altitude and 100 degrees +.
As a backup son #2 has a '05 Suzuki Gixer Litre sportbike. That thing turns low 9s box stock. Maybe we can make some money in the process.
I'll keep you posted.
Thrasher CAI, DHP v1.0 ECU, Granatelli CAI Tuneable MAF,
3.4 SC pulley, Hi-Flow CAT, u-bend delete, 180 TS,
TB spacer, MSD 8.5mm wires, AC Delco 41-932 spark plugs,
Goodyear Gatorback Serp. & SC Belt
ET: 14.3 @ 96 mph
Timeslip 08/12/06
AF Community Guidelines
Old 06-01-2005, 01:33 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
ET: 14.3 @ 96 mph
No, I was talking about the wheelchair ramp.
You know, know of a couple of guys that are running 10's. But that takes alittle work.
You know talking about that. Knew I keep this for a reason;
Performance Recipes
How fast is my L67-powered car in stock form?
We get asked this question all the time, so we’re going to give this our best shot…
If you have a ’97 to ’02 GTP or GS, your car will run about 14.8 in the quarter mile in stock form. There are lots of variables here, but this is a realistic average based on our experiences. If you have an SSEi, your car will be about one second slower. The Bonneville’s are only a few hundred pounds heavier, but they are slower for several other reasons too:
additional weight (several hundred pounds)
poor weight distribution for drag racing (things like the battery in the back seat, aluminum hood, aluminum control arms and aluminum front bumper all work to reduce the percentage of weight on the front tires, resulting in less traction during acceleration)
larger front brakes (more rotating mass reduces power put to the ground)
larger tires and wheels (increased rotating mass takes more power to accelerate)
restrictive PCM (much more aggressive traction control system cannot be overridden by simply pulling a fuse; PCM will actually retard ignition timing if you try to power-brake the car)
no Performance Shift function (so shift points are lower and shifts are slower)
no air opening behind the headlight means that removing the headlight won’t give you any cold air
The Regal GS is slightly (a couple tenths) slower than a similarly equipped GTP, for some of the same reasons as the SSEi.
There are MANY different possible paths to get you to a certain performance goal. Following are some EXAMPLES of recipes that we know work:
How can I get my GTP or GS to run in the low fourteens?
one step colder thermostat (180 degrees)
one heat range colder spark plugs (AC Delco 41-932 or Autolite 605 or NGK TR55)
cold air induction
3.40” supercharger pulley
How can I get my GTP or GS to run in the high thirteen’s?
two heat ranges colder spark plugs (AC Delco 41-919 or Autolite 104 or NGK TR6)
cold air induction
3.25” supercharger pulley
INTENSE 1.90:1 rocker arms/pushrods package
free-flowing cat-back exhaust
How can I get my GTP or GS to run in the low thirteen’s?
two steps colder thermostat (160 degrees)
cold air induction
3.10” supercharger pulley
SLP headers, downpipe and free-flowing cat-back exhaust
DHP PCM
mix of unleaded race fuel
drag radial tires
How can I get my GTP or GS to run in the high twelve’s?
three heat ranges colder spark plugs (Autolite 103)
cold air induction
ZZP throttle body
3.00” supercharger pulley
Lucas 42.5 pound/hour fuel injectors
INTENSE Stage 1 Blower cam/pushrods/rockers package
DHP PCM
INTENSE Transaxle with INTENSE Limited Slip Differential and 3.29:1 final drive
street slicks
How can I get my GTP or GS to run in the mid twelve’s?
cold air induction
ZZP throttle body
ZZP supercharger
2.80” supercharger pulley
Walbro fuel pump
ZZP intercooler
INTENSE Stage 2 cylinder heads
INTENSE Stage 2 Blower cam
DHP PCM
INTENSE Transaxle with INTENSE Limited Slip Differential and 3.69:1 final drive
street slicks
All the above numbers are GUIDELINES only, and make a few assumptions:
We assume you race at a reasonable altitude. You won’t be able to match these times if your track is 5,000 feet above sea level for example.
We assume that you race in good weather conditions. You won’t be able to match these times on a hot, humid day with low barometric pressure.
We assume that basic race preparation is done to the car. Remove the spare, empty the trunk, remove the floor mats, race with a quarter tank of fuel, set your tire pressures properly, etc.
We assume that you launch your car effectively. This is the most important part of the quarter mile race, and without a good launch, you will NOT be able to achieve your best E.T.
Yep, alot of work.
Old 06-01-2005, 02:11 PM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
Nice tips Jim (KustomKid54). Anythings possible but its all relative to how dinero $$$ you are willing to shell out. Money buys anything to include women.
Evidently, the L32 GTPs with the Series III 3800 takes to mods better than the older RPO L67. Must be that Eaton Gen 5 blower over the Gen 3 or that new electronic throttle control. The GM engineers must have done something miraculous to the FWD, drivetrain/gearing and 4T65E - HD tranny to sustain high 11 - 12 seconds runs. Sounds like a ticking time bomb to me. Just my 2 cents.
At least I've made the 91K mile mark (no engine or tranny problems) on my GTP without destroying the resale value.
ET: 14.3 @ 96 mph
Timeslip 08/12/06
Old 06-01-2005, 02:34 PM
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
ET: 14.3 @ 96 mph
Resale? Had a kid wanting to buy my car. He wrote and asked how much. Hadn't thought about it. Gave him 3 prices, with and without stuff. He wanted the car done with everything. Then he wanted it for a $1,000.00 less then I wanted for it with nothing. That's not young. That's plan dumb.
Don't forget the pictures this weekend.
Good luck.
Old 06-01-2005, 04:00 PM
jeffs_GTP_sleeper's Avatar
jeffs_GTP_sleeper jeffs_GTP_sleeper is offline
Speaking of ClubGP, you know I didn't see his '04 GTP 1/4 mile time listed
.....11.91 @ 114.8???? Did you?
It is there listed on the first page at [email protected]. My name over there is jeff johnson.
I am also listed on 3800pro.com here:
http://www.3800pro.com/lists/fwdquarter.html
This is my slip:
Do you need a vid of my 11.9 pass? Here:
http://www.angelfire.com/rebellion2/...1.9_114mph.wmv
rightclick and save
No I have never blown a tranny/engine. if it does happen I will have to eat 3-600 on another shortblock, which isn't that bad. I have been to the track many times with consistant 114mph traps and no problems.
Have fun sucking at modding!
Old 06-01-2005, 06:15 PM
BNaylor's Avatar
Oh wow! Deep pockets. When you get to our age in life you'll find other things to do keep yourself gainfully active and employed and not have to depend on mom & dad's money modding some car that will be worthless in less than 5 years. We may be old, cynical and crusty but we're not stupid.
You know I really don't think that any one on the GP forum gives a hoot about you or your car.
Plus you should think about improving your vocabulary or just stick to the Street Racer forum. That's twice you said that word.
When you make it to 91K miles and 7 consecutive years at the dragstrip with your GTP actually winning money then come back and talk your B.S.
Everything was fine on the message thread until you threw in your 2 cents and flamed everyone. The original poster was limited to a $500 budget and in the end made the right choice by not wasting a dime on his GTP.
3.25 SC pulley, Hi-Flow CAT, u-bend delete, 160 TS,
TB spacer, MSD 8.5mm wires, Autolite 104 spark plugs,
Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials
ET/0-60 ft: Pending
Timeslip 08/12/06
Old 06-01-2005, 06:29 PM
ET/0-60 ft: Pending
Bob,
Check your computer. It seems to have a "dumb magnet" on it lately. Wonder if he's friends with.............
Told you he would be back.
Old 06-01-2005, 07:35 PM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
Bob,
Heeeeeees back! Isn't that virtual police officer Big-L. Yeah a lot of B.S. comes down my DSL line. Speaking of computers I'm taking delivery sometime next week of a new P4 3.0Ghz plus computer and getting ready to swap out. Do you think that if I put an intercooler on my CPU that it would void my warranty? How about a 10 psi waste gate for turbo mode?
"I feel the need for speed". Later.
ET/0-60 ft: Pending
Timeslip 08/12/06
Sorry you have to resort to bashing my family.
Money is not a controlling factor in my life. I am sorry you are a slave to the dollar.
I have fun riding in my modded grand prix, sorry you have not had the same experience.
Sorry you can't accept the fact that it is possible to spend $500 on a Grand prix and be happy with the results. If you want to have a closed mind fine.
Have a great day.
Old 06-01-2005, 08:15 PM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
I wouldn't think that money is a controlling factor in your life, especially if you don't have any and are depending on mom & dad footing the bill.
Have fun riding in your GTP and have a nice life.
As to experiences, I have more fun with this. Yes, its modded to the gills too but the only difference is it takes a real man to ride one and win. Haven't lost a single race the past year and a half in the Vet. class. BTW - I'm over 50 y.o. and started out with a 1970 Chevy SS454 LS6 which was a real musclecar.
Timeslip 08/12/06
Old 06-01-2005, 08:46 PM
Have a great day.
There is no troubles here. If you would have read the posts, you would have seen the reply from the man that made it. He doesn't really want to spend the money, he wants a BMW. He has from the first day that he came on this site.
I know you came from another part of this site, which is great. If you had spent a little more time here, you would know the people. The guys that have been here a while are pretty close. We email each other more then we are on here.
OH, also. The one nice thing about old people. Have have the things in life already that we hope you do when you hit 50. I like to buy cars and hold them for my kids. I still have the 1966 GTO I bought in 1966. Also has less mileage then your o4.
We enjoy cars. We enjoy the company of friends. If you are going to spend time here, relax, enjoy, have fun.
Old 06-01-2005, 09:08 PM
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
Why are you so interested in my money and my moms and pops?
A real man does not come on a message board to claim he is a real man.
You are beyond help if all you see are stereotypes. Sorry you are so fargone.
Nice bike.
Old 06-01-2005, 09:30 PM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
Nice bike.
If you think that I'm that fargone or crazy you ought to see me freestyle off a 30 feet sand dune. BTW - Glad you liked the bike.
Timeslip 08/12/06
Old 06-01-2005, 09:31 PM
Nice bike.
Not interested in your's or your Mother's or Fathers money. Just replying to replies above.
But, I know I'm not interasted in talking with you anymore.
Enjoy whatever you do. Hope things turn out well for you.
Old 06-02-2005, 02:13 AM
BNaylor's Avatar
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: What MOD to do next!?
Jim, the best thing to do is ignore him. He who angers you controls you. Let him be someone elses problem. Good night.
Timeslip 08/12/06
