#16
I'm using the lt1 fans out of a camaro with a Nelson wiring harness and my pcm is running my fans, as well as my ac. I have no cooling problems whatsoever, and this is on my stock radiator.
![]() Daily Driver- 00 Camaro SS A4 1/4- 12.30@118mph 2.14-60ft on street tires Weekend Warrior-99 Silverado "Dirty" 1/4-11.63@118mph 1.8-60ft |
#17
Re: LS1 Fans
Slowprocess, what does your Trans Temp run?
#18
Re: Re: LS1 Fans
#19
Re: LS1 Fans
Your trans has been modfied slightly, LOL, so it can handle the higher temp right? Did you add another in line trans cooler or just the stock cooler setup? From what I've read and heard from others is that getting to 210 will shorten the life of a stock trans. Do you agree?
#20
Re: Re: LS1 Fans
#21
Re: LS1 Fans
Once my truck gets to operating temp the tranny starts the creep up to 190. Once at 190 it won't go down until I get above 60 for a run. Talking with Allen the trans should run 160-165. The air temp around here has only got to 92-95 and it looks to be 100+ sooner than later and I really don't want to see my trans temp get higher.
After looking at the new trucks I found the 6.0 Liter trucks have the 34x17 radiator with electric fans. LARGE fans, I did say LARGE didn't I?? Curious how well they work for a GM part. Can't hurt to put a larger radiator and fan setup in my truck. Now to be able to afford it, radiator and fans. I am not saying the LS1 fans are bad, just not as cool as I want it to be. |
#22
Re: Re: LS1 Fans
#23
Re: LS1 Fans
I found a company locally that makes a 34" cooler with oil cooler and trans cooler internal for $230, not bad. Then to see if I can find a used elec fan from a 34" rad. Soon, soon....
