Old 05-08-2005, 01:07 PM
JESUS Y ADA JESUS Y ADA is offline
Re: Re: Help on bumper lights!!!!
Originally Posted by Team PHATBOYZ
So your sayin tat it can't be done then?
JUST GO TO THE JUNK YARD AND CUT THE PLUGS FROM THE TAILLIGHTS THAT HAS DUAL FILLAMENT BULBS CUT YOUR STOCK ONE CONNECT THE GROUND ONE FOR YOUR TURN SIGNAL THE OTHER ONE TO YOUR CORNER LIGHT THAT IS HOW I GOT IT DONE ON MY CRX IF YOU NEED PICTURES I COULD POST THEM JUST LET ME KNOW
Old 05-08-2005, 08:30 PM
Team PHATBOYZ's Avatar
Team PHATBOYZ Team PHATBOYZ is offline
Send a message via ICQ to Team PHATBOYZ Send a message via AIM to Team PHATBOYZ Send a message via Yahoo to Team PHATBOYZ
Yeah post them please and show some pics of how you wired it. Thanks
4TH GEN CIVICS ROCK
Old 05-09-2005, 07:50 PM
Re: Re: Re: Help on bumper lights!!!!
I'll Charge My Camera Tonight And Post Some Pictures Tomorrow
Old 05-10-2005, 12:39 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
did you even look at the link i posted ?
Team Lonely Drivers
Old 05-10-2005, 11:53 AM
I CAN'T LOAD THEM IF YOU GIVE ME YOUR EMAIL I WILL SEND THEM TO YOU. I GOT THE PICTURES OF HOW I DID IT
Old 05-10-2005, 01:38 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Would this not be the same principle as side marker lights? Side marker lights do not stay lit up when they come stock on a vehicle. However, I had side marker lights on my CRX and they came on with the lights. They were just tapped into one of the bulbs of the corner lights (forget which one) to the respective + and - and they actually did blink intermittantly with the corner signals and bumper signals. I removed them because I believed they were creating a short. They were not fused. I did not originally wire them.
Anyway, be careful with stuff like this cuz you can end up creating problems that originally weren't there... Splicing them probably isn't the best way to go about it... fuses are good too...
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-10-2005, 04:13 PM
my email is [email protected]
4TH GEN CIVICS ROCK
Old 05-10-2005, 04:14 PM
Yup, i ended up fucking up my harzard lights and my left signal because i tried to splice them, so now they don't work? Can i fix them some how?
4TH GEN CIVICS ROCK
Old 05-11-2005, 04:11 AM
on my car the corner lenses lights up and blinkes, if yous does the same, just tap into that
Team Lonely Drivers
Old 05-11-2005, 09:46 PM
So just use one or two wires to connect to the bumber lights and the corner lights?
4TH GEN CIVICS ROCK
Last time i tried that, my left signal stopped working
4TH GEN CIVICS ROCK
Old 05-12-2005, 04:29 PM
does your rear corner light come on with your lights and blink, or do they only blink ?
Team Lonely Drivers
Old 05-12-2005, 10:24 PM
are you talkin about the amber part of my tail lights? if you are, then no it only comes on when i signal.
4TH GEN CIVICS ROCK
Old 05-13-2005, 07:42 AM
I can't remember but I believe that's the way it's supposed to be and is hooked up together by way of relay. So, I would think you need a dual filament bulb for your parking lights and would need to tap into the non-amber part of the corner lense. Even if you do get it to work, you'll be drawing excessive juice through that circuit having those bulbs on all the time with your lights. You probably don't believe me but my bright ass side markers were like that (stayed on with lights and side markers are supposed to just blink with signals) and when I rode with my lights I noticed a power loss but never could figure out why. I believe that lack of a fuse in the circuit put a strain on the ground. But I had an amp, subs, neons under the seats, a/f gauge as well as having my fan wired to stay on all the time. It was a wiring mess. I removed the amp, subs and side markers and pretty much rewired everything cleaner and more efficient. Fan is now powered through stock + wire but since relay is missing wire it's still just grounded with - part of circuit and chassis and works with stock fuse. Basically, I'm saying use fuses and wire it clean and nice and you'll have less troubles...
2010 Honda CR-V EX
Old 05-13-2005, 09:49 AM
chunky01 chunky01 is offline
I bought lighted mirrors for my car but there was no wiring diadram in the box. I need help on hooking them up correctly where it would work with my signal lights too, any suggestions?
