| Non Specific This is the forum to post and generalized racing questions. |
#16
Re: Probably gonna slow me down...
Ah ok.
2006 Redline Red Nissan 350Z Base K&N|Falken I am just that JDM tight, yo.
#17
Re: Re: Probably gonna slow me down...
1995 3000GT VR-4 Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup. Soon:Topline Engineering ground wires. |
#18
Wouldn't two medium size turbos spool up much sooner than a single large turbo?
#19
That's nice! I've never seen a 3rd gen block tore down to the lifter valley! It looks.....different!
Anyways, what kind of heads are you leaning towards??
**1966 Chevy II** ![]() 355 SBC, Turbo 400, 5.13 gear, IHRA Certified to 8.50 in the 1/4 Last Race (10-6-07) So its been awhile... Dial: 6.77, RT: -.0001, 60': 1.4360, 1/8th: 6.7942 @ 100.65 mph Fastest Pass of '07 (10-6-07) 60': 1.4360, 330': 4.3453, 1/8th: 6.7942 @ 100.65 mph 25 and in BIG TIME Debt Crew member #2 Deuce's Wild Racing: Take a Ride on the WILD SIDE
#20
Looking to AFR when I have the money.
1999 Pontiac Trans Am WS.6 #1747 Stock'ish' |
#21
I heard that. That's the kind of heads I want for when I'm able to build another motor.
The race ready AFR allum. heads would be awesome I think. You can get them with 2.10 intake and 1.60 exhaust valves, and 66 or 74 cc chambers. Sounds pretty impressive. They are like $1500, which is really not that bad. Now Jegs makes heads too for SBCs, and I wouldn't mind getting a set of them either. They have a set in their current catalogue that has 2.10/1.60 valves and I think 74 cc chambers that make 650 hp on a 406 with 13.5:1 pistons and like a .680 lift cam. Now that's not bad at all!
#22
Wow, I wish they made aftermarket heads for the VR4
stage 3 heads from Dynamic Racing cost $2400, and they're just reworked stock heads. And Clawhammer, two half sized turbos would spool faster but with a 6L engine with heads and cams he's not goign to need all that much more power early in the powerband, when he wants it its there on tap.
#23
Whoa..you're paying big money for that kind of horsepower. You coulda bolted on a supercharger and got 600rwhp. Or do you have plans on running FI on that motor and having like 800rwhp?
#24
So even like the AFR heads I mentioned in a previous post ($1500) still are not ported and cut or anything, and that usually cost about $600 to get done, so there's $2100, lol. To build a near 600 hp small block chevy, you can figure on spending atleast $6000--and that's if you already have a block, distributor, headers, fans, water pump, and all that kind of stuff. You can figure $1200-1500 for rods and pistons, a steel crank is pretty high as well, probably $500 or more, around $600 for roller rockers and lifters, $250 or more for an intake, say $2000 for a good set of heads, $500 or so for a carb., you get the idea.
#25
600 rwhp is nothing to laugh at. Alot of track only cars don't make that kind of power.
#26
Cool. I guess with a 6 liter engine you already have lots of low end torque. What hp are you hoping to have in the end? What times are you aiming for.
#27
I want 12's here on street tires.
500+ RWHP. Same with torque. And guys, 402ci = 6.6L (roughly) Yeah, it is a LOT of money. But forged LS1 parts are. This motor is capable of handling up to 1,000 HP, maybe even more. A supercharger would have gotten my car to around 550 RWHP. For slightly less money. But at that point, I am still running stock internals, and starting to get them to their breaking point. I am going to have a complete powerband with this motor, unlike the torque curve I would have with the smaller displacement S/C'd LS1. I think in the end, I will be able to pull S/C'd LS1 cars. If not pull, at least make it VERY interesting. Plus, I will look stock under the hood, for the most part.
#28
Talk about a visual difference.....
Intake/Exhaust Gross Valve Lift = .629/.622 Advertised duration = 297/306 Duration at .050 = 248/254 Lobe lift = .3620/.3610 Lobe Separation = 113
#29
I have been doing some research on twin turbocharging. I used to think the same thing until I found a few things. Get on AIM tonight and I will share my findings. BTW 10:1??????/ BOOOO go 8.5:1 and run 26 PSI ![]() Man this is BS..... I post up a block I bought that came out of a MCLARIAN INDY CAR!!!!! and I get a few "oh thats nice, blah blah blah "oh you think you might hit 10's?" Mr. Lous post up a block that came out of a production truck and everyone is like "'OHHHHH LOOK AT THAT, THATS PURDY, CAN I TOUCH IT, IT'S SOOOO BIG." Screw you hippies, Im going home. J/K nice block, finally someone has the balls to pull that alum. POS block out of a F-body and put a real cast iron block.
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
#30
Re: Re: Re: Probably gonna slow me down...
