| Off-Topic Talk about anything other than cars. |
#16
Re: Re: EvoIII 16g'ed
Just busting your balls... if you can't log and can't afford to fix broken parts, it's good to stay below 15psi on the 16g. For the record, 2g stock boost is supposed to be 14psi. Quote:
Also note that I said that a stock 2g pump IS good for 40 lbs/min, which is more than 99.99% of poeple ever actually hitting that. Me being in the .01 that has of course Quote:
Also note that any time boost is dropping with rpm (over 5500 rpm on the t25 at any boost level over 14 psi), you have either maxed out the compressor, or maxed out the turbine side (WG is blowing open frome excessive exhaust manifold pressure due to the restrictive turbo), the jury is still out. I should also mention that your last statement defies the laws of physics, since the gasses coming out of the turbo, regardless of pressure or temperature, will take up the same amoutn of space, since it is in a confined location and gasses completely fill thier container. The exception is in dynamic situations, but it still applies, just not linearly. Quote:
For the record though, I ran into the 12s on stock injectors over 100% IDC, low 12s on 660s at ~110%, and into the 11s with 850s over 100%. I've had the 950s as high as 90%, but I am upgrading to 1600s to get back down to ~60%. Quote:
![]() Not picking on you specifically, just posting on these points because I feel I have some decent personal experience with them over the last 5 years.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
#18
Re: Re: Re: EvoIII 16g'ed
Which is exactly why my tune is safe. Yes I did make it to 104 IDC%, butr with regard to what Kevin said, this is why I am ok as far my air/fuel ratio. I was in the low ten's (estimated A/F as per DSMlink). Thus, when it did lean out, and only for a small while at higher rpm's, My margin of safety was still there. ![]() PS: You beat me to the airflow arguement. I knew that was going to be coming as soon as I saw CFM.
Aaron B. 95 TSi DSMlink'ed Evo3'ed 6 bolt 52.7 1/4 second try 11.0 1/16th 2nd in league. 22.3 1/8th Ties league record. 6.6 55 meters Last edited by TsiTalon9587; 04-12-2005 at 07:30 PM. |
#19
Re: EvoIII 16g'ed
lol, wow this thread has got way confusing, it's interesting to read all this stuff though, maybe ill learn something. but still im a little confused, give it to me in dumbass terms please (yes/no/or do this dumbass) with my mod list, what psi should i set my boost at???
95' Gs-t (broke the fuck down...) 68' Mustang getting reassembled right now, 82.763% done ![]() ![]() http://www.tagworld.com/milton666 |
#20
![]() I agree.. this topic is very informative but yet above my comprehension as for tuning!!! Kinda worries me for when I want to start boosting high... like 18psi and over...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan |
