Old 03-23-2005, 05:52 PM
3wbdriver 3wbdriver is offline
Question Stuck out there
I looked at the specs on the Eagle rims you are looking at. The offset is 4" on the back. Your stock rims are probably 6 or 7" now with most stock rims having a 4" offset. So any width you get will be going out. From the pic, you look like you have 1 1/2" - 2" to play with. When I checked the offset on the rims I got, I found out they were 3 5/8" offset. So when all was said and done, I actually pushed my stock skinny sidewall out almost 4". Here's my truck the day after I bought it. With 8" wide rims, these same tires now come slightly past flush with the top of the rear fender. The fronts actually stick out a little. Sorry, but I misplaced my camera during a move, so I don't have any pics of the new rims. Hope this helps. BFG by the way, recommends a 7" - 8 1/2" rim for your size tire. Oops, looks like I gotta figure out how to post pics................
Old 03-23-2005, 05:56 PM
TwentyPints TwentyPints is offline
Re: Everyones opinion on these rims
thanks for that explanation.
so i suppose 16x10 is not a wise choice.
K&N High-Flow Air Filter
Flowmaster 40 Series Muffler (Dual Out)
Vibrant Performance Exhaust Tips
BFGoodrich Mud-Terrain T/A LT265/75R16
Clarion Pro Audio System
Old 03-23-2005, 06:01 PM
See if a local shop will let you hang one off the front corner. Guesstimate how much more sidewall you'll have, and you should get a good idea how they would look. I recommend the front because the body is narrower up there than the rear.
Old 03-23-2005, 06:06 PM
i would like them to stick out a bit more but i dont really have much room in the front as it is...but pushing it out would that make any difference in the tire rubbing?
Old 03-23-2005, 06:15 PM
It's possible. That is a concern I have about going to a taller tire. Crank your wheel all the way one direction and see how much clearance you have from the rear fenderwell. That is where it looked tightest to me. I still haven't heard anything from the swap, but I know it has to be close. Guess what I just found!? PM me your email, and I'll send you before and after pics.
Old 03-23-2005, 06:28 PM
at full crank there is not much room at all..maybe a couple inches
Old 03-23-2005, 06:50 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: Re: Re: Everyones opinion on these rims
Originally Posted by Faze3
Hey! I happen to think those look better than the American Racing ones.
At least they're not spinners!
Everyone has their own personal preference and are allowed such , i just do not like the looks of them is all. I do agree about the spinner comment though lol
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 03-23-2005, 07:16 PM
I'd go with the 8", on those tires, or you may end up looking like a 4x4 that's been bagged! LOL...... Thanks for the help.
GAS IT TIL YOU SEE GOD, THEN TURN LEFT!!!!!!
Old 03-23-2005, 07:26 PM
good call... 8's it is.
Old 03-23-2005, 07:43 PM
J-Ri's Avatar
J-Ri J-Ri is offline
American Racing. I don't especially care for the 3 spolk design myself, but the other ones look like they should be on a ford.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-23-2005, 08:27 PM
I want to see a pic of whichever you go with. You may have convinced me to go up to 265's.
Old 03-23-2005, 11:02 PM
Moose is loose Moose is loose is offline
Go with the 8's. They will look wider (cause they are) than your stocks. I just had a set of Pro-Comp series 8089's put on today. They are the same rim as the 6089, but powdercoated black in the center. They just came out, so no pics on the net yet, but they look bad ass. This is my 2nd set of Pro-Comps. They are outstanding wheels IMO. GREAT warranty, and I can leave them on all year too!
Old 03-24-2005, 02:19 AM
how are pro comp's price wise?
3wbdriver -- some 265 m/t or a/t's would look great on your truck.
Old 03-24-2005, 11:34 AM
would 16x8 with my tires fit without any rubbing?
Old 03-24-2005, 12:30 PM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
I have 20x9s on my truck. No rubbing at all lock to lock. But b/c of the size tires you are going to put, I would also suggest 8" wide.
*Under Construction - New sig to debut*
