Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-23-2005, 07:10 PM
sil8thyhavoc sil8thyhavoc is offline
Send a message via AIM to sil8thyhavoc Send a message via Yahoo to sil8thyhavoc
Re: Re: Re: Re: overheating
Originally Posted by Hit_N_Run-player
I doubted my radiater too, then i found a hose leak so i replaced the radiator for nothing.lol
ok i changed the radiator cap and its still doin it. im not sure but im thinkin its the thermostat i just got it from some foreign parts place. i was thinkin about gettin an oem one but im not sure.
Old 03-23-2005, 07:12 PM
i replaced the radiator cap and its not it. its still overheating. im think its the thermostat but im not sure cuz i just got it from some foreign parts place. i was thinkin about getting the oem one but im sure. other than that i realli dont kno what it could really be.
Old 03-23-2005, 07:14 PM
Re: overheating
i replaced the radiator cap. its not it. its still overheating. im sure wat it is, but i thinkin its the thermostat. i just got it from some foreign parts place. should i get the OEM one or not? its 170 degrees. thats the stock one right?
Old 03-23-2005, 08:26 PM
Hit_N_Run-player Hit_N_Run-player is offline
Send a message via AIM to Hit_N_Run-player
Re: overheating
so you bought a new thermo? and you think its bad? Is there any leaks anywhere? How much did you pay for this thermostat? Maybe you should go down to baxter or a respectable parts store and buy the right thermo.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Old 03-23-2005, 09:34 PM
my240project's Avatar
my240project my240project is offline
Man i am having the exact same problem but ive done everything and nothin gets better, it seems to be getting worse, ok i have changed out the waterpump, fan clutch, 170 degree thermostat, gone thru two radiator caps bought a new 16lb and now ive got a 13lb, flushed the radiator, and took it today to have it rodded out and just put it all back together and its still over heating, it all started about a month ago when i put the water pump on, i have heard that u have to pay attention to buying water pumps from places other than the dealers because the propellers on the auto parts store pump arent always the exact length of the oem is this true? i am at my wits end with this car i am seriously contemplating selling it ,nothing but trouble and its busting my bank ,what is there left to do?
Old 03-23-2005, 10:00 PM
Re: overheating
are you guys filling the radiator with coolant right? Do you know how you properly do it? You dont just poor it in...
1988 conquest TSI
Torque wins races!
Old 03-24-2005, 03:27 AM
DAS14SNIPER DAS14SNIPER is offline
Flush It Water First,let The Therm Open
Flush It.let It Cool (if Your Rad.works Cool H20 Will Come Out First Then Hot From The Block.)
Fill With 5050coolant(best Choice)
Fill Resvior Between Min & Max
Let Therm Open
This Is The Tricky Part
The Reservior Coolant Is Suppose To Be Suckd In By
Vaccum (but That Wont Really Do The Trick.)
Check And See If The Coolant Is Being Drawn Into The Radiator
If That Doesnt Work Then Then Ill See Your Post Here I Got A Bunch Of Info On Overheating.goodluck.
Old 03-24-2005, 03:35 AM
If The Gauge Doesnt Stay In Normal Operating Temp
For A Lil While Then Its Your Therm.or U Just Test
It Compare To The Old One (in Hot Watta)
Yes Experience = Headache/$$$
Old 03-24-2005, 10:47 AM
yes i am filling it right. i have also opened the bleeder valve for around 30 mins and nothin but either bubble or a foam like stuff comes out never actual stream of coolant/water. any one know about the water pump question i had? if the propellers are always the same from autoparts store to oem? and since i have put the radiator on last night when i drive the temp gauge goes down when im on the gas but as soon as i push in the clutch to shift it goes up the when i let out for next gear it shoots back down. so whats the deal? DAS14sniper i believe i need all ur overheating info. haha
Old 03-24-2005, 11:44 AM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
Re: overheating
if you are using a thermostat from autozone it will ALWAYS overheat. they don't have air bleeder holes in them.
go to your local nissan dealer, buy a radiator cap and thermostat. oem stuff is always best.
if its still overheating check if your fan is working. mechanical fan? ok, if so that's not the problem.
do you have a front mount intercooler? if so its definitely your radiator. the fmic blocks air coming to the radiator, so you need more radiator thickness and it almost has to be aluminum. koyo sells an awesome one for around 300/shipped.
if you are still overheating its either your water pump or there is shit in your engine's head, or a bad head gasket.
make sure you are bleeding it correctly.
1. Fill the overflow tank to the full line.
2. Make sure heater is fully on the hot side.
3. Remove engine bleeder screw and radiator cap
4. Fill very slowly until coolant comes through bleeder.
5. Close bleeder.
6. Continue filling until radiator is full.
7. Squeeze all hoses to release more air. Keep radiator topped off.
8. When full, install radiator cap and run engine.
9. Fill overflow and radiator as necessary. Keep heater on hot.
10. Hope to god it works because you really don't want to repeat the process again.
438whp / 373tq - 11.9 @ 126
Old 03-24-2005, 03:34 PM
Re: overheating
Check Your Electric Fan If Turns On.
If It Cools Down When U Drive It, Coolant Is Flowing.
Hows Your Clutch,did U Changed It Recently
I Read That If Your Clucth Is Worn Or Not
Properly Alligned Its Causes Heat From Friction Heat Transfers Make Your Block Hot.im Going To Look Up The Source And Give The Link.(i Never Heard Of It But It Could Be Possible )
Old 03-24-2005, 05:06 PM
Re: Re: overheating
5. Close bleeder.
I dont know what DAS14 was trying to say, but this is the proper way to fill with coolent. Leave the engine running after you do this for about 5-10min, then come back and open the radiator and see if its still full...
1988 conquest TSI
Torque wins races!
Old 03-24-2005, 05:39 PM
Chuki_breath Chuki_breath is offline
Re: overheating
yea i was thinking head gasket....thats what caused my car to overheat all the time. Got a new one and it runs at correct temps. Yea, it cools down when your moving then you slow down or stop and temp gauge goes up up up. Then you get going again and down it goes. I feel ya on that, i had to drive in the summer with my heater on....talk about schwetty balls.
Old 03-24-2005, 08:49 PM
yada yada yada
Re: overheating
i didn't even follow those myself lol. just undo bleeder screw, fill until it topples out, close it off, and fill the rest up. put radiator cap on and go drive. past that the cooling system will basically bleed itself.
Old 03-24-2005, 11:00 PM
ok guys i appreciate all of ure help...it wasnt the water pump, thermostat, electric fan, radiator cap... it wasnt none of that.....pist me off tooo......my cluster was bad.........i changed the cluster and everythin was normal......can believe it was the fuckin cluster......all that work too....
