Old 03-16-2005, 02:04 PM
RG501 RG501 is offline
Send a message via AIM to RG501
Re: sterio and speakers
can you give me a link to a small 4 channel?
Old 03-16-2005, 03:33 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
http://www.millionbuy.com/caudio-amp-prf.html
But SR is right, the popping is not from underpowering, your speakers are hitting there limits. So if you do add a 4ch. amp, i say upgrade your speakers. If your not goin to upgrade, then High Pass Filter your amp so you dont send your speakers low freq. an hit there limits
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
Old 03-16-2005, 08:32 PM
so if i wanted to power my 2 6x9s, the 2 on the front doors and a sub, i would need a 5 channel amp? how many watts should i get?
Old 03-17-2005, 12:50 PM
Mannyb18b's Avatar
What kind of sub? you have to understand that not much power is goin through those five channels, an most likely not enough for a sub. 5 channel amps are usually for speakers and maybe a small effecient sub. Get a 4 channel if you have to use your rears too, but i'd suggest just a nice component set up front an ditch the rears. For a sub, get a Mono amp an run the sub off of that
Alpine H/U-
CDT EF-61's
NSB-100
Old 03-17-2005, 02:22 PM
i have a Legacy 10" sub. it says its rated for 400watts. i just want my music to be louder.
Old 03-17-2005, 02:30 PM
you said youd suggest ditching the rear. do you mean dont even amp the two 6x9s and just amp the 2 in front and a sub?
Old 03-17-2005, 03:27 PM
Mannyb18b's Avatar
Basically, because thats the best imaging. Your listening to music next to and infront of you, its not coming from the rear. But it wouldnt be much of an advantage if you just amped stock front speakers. Get a nice front component set consisting of Midbass, Tweeter an X-over. What kind of Head Unit do you have? Give me a budget on Front Speakers and amp an ill recommend you somehting.
Alpine H/U-
CDT EF-61's
NSB-100
Old 03-17-2005, 05:16 PM
well i already got some new 6x9s and i would kinda want to imclude those in my system. as far as front speakers and budget, i dont want to spend much. my head unit is a Kenwood 45X4.
