Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 09-12-2005, 12:21 PM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Good to know, thank you for updating.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
  #17
Old 09-13-2005, 12:17 AM
Booch Booch is offline
For what it's worth, I've always used the Taylor wires from Summit or Jegs. They have a really positive lock on the plug end (you can hear them click as they engage), and easily handled the heat and power from my old 470 hp 402 BB Chevy I had in a '78 Monza a few years back (MSD Blaster 2 coil, Accel unilite 5000 distributer,etc).
The part number we need for 4.3 liter 1996 - 2003 is 74X35 - 91035.
Taylor's homepage is http://www.taylorvertex.com/hp/ , and their application guide is http://www.taylorvertex.com/PDFS/Page53-64.pdf
These are what I'm buying when it's time to change the wires on my 02 Xtreme.
  #18
Old 09-13-2005, 07:37 AM
muzzy1maniac's Avatar
muzzy1maniac muzzy1maniac is offline
Re: Re: Re: Re: Bought new ignition wires.
Originally Posted by BlazerLT
Here I am trying to do something good and change the cap and rotor and I end up screwing something else up.
My life's story bro...
2004 Explorer XLT
4.0L 4x4
1998 Ranger Supercab
4x2 3.0L
Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store!
Come visit me on www.faceforums.com
  #19
Old 09-13-2005, 07:54 AM
blazee's Avatar
blazee blazee is offline
Problem?
I've got nearly 40,000 miles on my autolite wires. If you do the job right and do a complete tune-up all at once, there is no need to remove the wires 6 months after installing them.
I've also got nearly 40,000 one my autolite platinum plugs. I did go with AC Delco cap and rotor, though, because of all the problems that people have had with the after market ones. My Blazer runs like new with almost 150,000 miles on it.
  #20
Old 09-13-2005, 08:24 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
That is wrong and you know it, they are junk and I'm sorry, but having plug wires that are only good for one time connection is garbadge.
I did the job "RIGHT" and I'm sorry that I didn't change the cap and rotor at exactly the same time as the wires. But saying that is an excuse that the wires are supposed to fail then you are full of it.
You don't replace your wires everytime you replace your cap & rotor or plugs.
Listen, 6 months and they failed when I pulled them off on TWO WIRES. This is poor workmanship and the connections are garbage compared to the stock wires.
1995 Factory Blazer Service Manual for sale, PM if interested.
  #21
Old 09-13-2005, 10:47 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Ok, update.....
AVOID AUTOLITE WIRES!
Just changed my cap and rotor and those new wires ripped the condictor out of the boot on two of the wires connecting to the cap.
PLUS, one ripped out when I was regreasing the plug ends as well.
These are made REALLY cheap and you can tell when you look inside the connections.
AVOID!!! My 10 year old wires are more durable that this.
i swaped my wires when i changed the cpi so i had complete access to the cap. my truck had ac delco wires on it and when i pulled them off, all of the boots tore off. cheap pos. i replaced them with 8mm accell 9000's for 70 bucks and they work great.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
  #22
Old 09-13-2005, 11:12 PM
BlazerLT's Avatar
AF -Advisor
Were you pulling on the boots or on the wire?
Did you have any dielectric grease on them?
  #23
Old 09-14-2005, 05:04 PM
blazee's Avatar
Problem?
What is wrong? If you do a full tune-up and replace everything..... why would you need to remove the wires 6 months later?
What did you expect? Of course the quality isn't going to be as good as the AC Delcos..... They are 1/4 of the price. Even though they are not the same quality, they still provide great performance and are well worth the money.
I have done alot of tune-ups in my lifetime. I've pulled lots of wires loose from the boots (only because I was replacing them) it doesn't matter if they were OEM or aftermarket, they all can break if removed improperly. If you want to reuse them, you have to remove them properly. The boots are there to seal the connection, because of this they create a strong suction when you try to remove them. If you want to reuse the wires you have to grab the front of the boot and twist back and forth as you remove the wire. You NEVER pull them off by the wire unless you are replacing them, because 80% of the time they will break. (Any brand will break) Of the hundreds that I've done I haven't broke any that I planned to reuse.
Calling a product garbage just because you handled it improperly and broke it, is just plain wrong and you know it.
  #24
Old 09-14-2005, 05:23 PM
BlazerLT's Avatar
AF -Advisor
Oh gimmie a break, what a stupid statement. You know the world does not work like that. Maybe someone didn't have the money to replace everything at once or maybe they didn't have the time.
This is no excuse for the part failing on me. You should have done it all and it is that problem that caused the part to fail.
What a idiotic statement, I thought you knew better than that.
Gimmie a break, again, a piss poor excuse. What, I buy ignition wires and they are expected to fail in 6 months because I didn't follow you "perfect tuneup" routine? You know that is bullcrap and a poor excuse.
You know what, why don't you ask me how I removed them instead of blindly saying I removed them wrong. OK>>>THANKS!!
When I installed them I actually added a good dose of dielectric grease to them to coat them properly, and they were perfectly on and were not stuck in any way or form.
Nice assumption there. Did I say I pulled them off properly? NO!
Did I use excessive force? NO!
Are you backing Autolite wires to somehow make yourself feel better that you use them.....YES!
They are garbage and not worth the money to install them. I would pay the extra money now.
Your post is nothing but a bunch of idiotic excuses.
Here they are all summed up:
1.) You should have installed the cap at the same time as the wires: RIDICULOUS
2.) They are cheaper, you shouldn't expect them to last: RIDICULOUS
3.) You didn't remove them properly: RIDICULOUS
So if you have the same wires, that is fine, it is your choice.
BUT DON'T YOU EVER SAY IT IS MY FAULT THAT THE PART FAILED BECAUSE OF THESE BULLSHIT EXCUSES.
KTHX
Thread is closed, obviously, some people don't have their heads on their shoulders.
AUTOLITE SPARK PLUG WIRES ARE HORRIBLE! DON'T USE THEM! NOT WORTH THE MONEY!
Closed Thread
