Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-26-2005, 11:48 PM
ludegurl's Avatar
ludegurl ludegurl is offline
Re: Help!!!! Big Problem!!! Confused!!!
Originally Posted by homer2nyce
Im confused. Ill be driving in my 98 lude for about a half an hour or so, when all of a sudden Im in first gear hitting 5000 rpms and going about 5 mph. Same in 2nd. I try to accelerate but cant get past at most 20 mph. Idk what it could be. The problem was first diagnosed by my very reputable mechanic as my clutch, so I had it replaced about a week ago and the problem is still there. I havent gotten a chance to tell him yet. In the meantime can anyone think of any other problems this might be. Thanks.
I think your clutch slip or your pressure plate is not putting enough pressure to hold your clutch.
Ive experienced that problem before and this is how i solved that problem: Cut the flywheel (shaded area with pink line) about 3/16 inch deep where the pressure plate bolt in. See the attached pic below. Cut only the shaded part of the flywheel, its from the outside diameter of the clutch disc to outside surface diameter of the flywheel. With this procedure, the pressure plate will put much higher clamping force on clutch disc.
Old 02-27-2005, 12:07 AM
homer2nyce homer2nyce is offline
Well to answer the post b4 the one on top of this one, yes, the whole clutch kit was replaced. Now gettin to the post b4 this one, thanks a lot, I appreciate the diagram too. Ill run that by the mechanic and see what he says. Still dont know exactly what is the cause of the problem tho..
Old 02-27-2005, 01:54 PM
ludegurl's Avatar
forgot to mention, the cause of the problem could be your clutch pedal.. out of adjustment. make sure your clutch pedal has free play of about 1/2 inch. if no free play clearance, it'll cause the clutch to slip, if clearance is too much, itll cause hard shifting. also you may want to bleed your clutch hydraulic system and replace with new fluid. if everything is adjusted properly and still having problem, do the procedure i mentioned earlier about cutting the flywheel.
Old 02-27-2005, 03:07 PM
Prelewd's Avatar
Prelewd Prelewd is offline
Send a message via AIM to Prelewd
We have hydraulic clutches don't we? Why don't you check where your fluid level is at in the slave and master clutch cylinder.. Also check the level while it's hot..
Soon..
Cars:
1990 Nissan 300zx Twin Turbo
1992 Honda Prelude Si 4WS H22a Swap - For Sale
1965 Chevrolet 1/2 Ton - 500ci Cadillac Cometh
1970 Datsun 240z - For Sale
1972 Datsun 240z - For Sale
1977 Datsun 280z - For Sale
1991 Infiniti Q45 - Engine Donor to 240z - Parting out the Rest
Sold Cars:
1976 Jaguar XJ-S - Rear end Donor to Chev Pickup
1971 Datsun 240z
1984 Civic 1500 Hatch
Old 02-27-2005, 04:22 PM
Phunyguy Phunyguy is offline
Send a message via AIM to Phunyguy Send a message via MSN to Phunyguy Send a message via Yahoo to Phunyguy
Re: Re: Help!!!! Big Problem!!! Confused!!!
i thought hydraulic clutches didn't need to be adjusted because it was "self-adjusting"
Old 02-27-2005, 05:27 PM
ludegurl's Avatar
Re: Re: Re: Help!!!! Big Problem!!! Confused!!!
yes, youre right. hydraulic type doesnt need adjustment. i was thinking too many things and got all mixed up with the cable type. actually i was getting ready to make corrections but i guess i was too late for that. at least i know somebody is reading my comments, thanks for the feedback.
Old 02-27-2005, 05:58 PM
ludegurl's Avatar
The hydraulic system on hydraulic type clutches are non adjustable. But proper free play clearance on clutch pedal is still needed or it will cause problems..see the pic below for adjustment specs.
Old 02-27-2005, 08:27 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
If the clutch system is low or out of fluids it will not cause the problem he is having. When it is low or out of fluid the slave cylinder will not put enough pressure on the clutch fork to release the clutch.
As for the cutting of the flywheel, I would rather not do that. You should not have to modify the flywheel to fix the problem. You need to find the faulty part and replace it or find the problem and fix it.
Old 02-28-2005, 03:24 AM
-JoeMama-'s Avatar
-JoeMama- -JoeMama- is offline
Banned
I just want to say thanks to ludegirl for the helpful comments on machining the flywheel. My wife had clutch slipping problem on her nissan sentra. Because the clutch slip, car overheated and burned the disc. it also screwed up the pressure plate and throwout bearing. We replaced clutch twice in 3 months. Yesterday, we again took the tranny off the car to find out whats causing the problem. We could not figure out til today when I saw ludegurl's comments. We then took the flywheel off the engine and brought it to Kragens Autopart to have it machined. They used their brake lathe machine to cut the flywheel just like ludegurl described it. They charged us $20 for the labor. We then re-assembled the car and installed new clutch and the modified flywheel. The car now runs perfect. It can even do burn out with no clutch slip.
Thanks Ludegurl
Old 02-28-2005, 02:32 PM
whtteg's Avatar
Thanks Ludegurl
Yes but like I said in my previous post, that is not the root problem. So by fixing it that way you are ignoring what is really wrong with it. Do what you want but if it were me I would find the actual problem and fix that.
Old 03-02-2005, 10:05 AM
toyme's Avatar
toyme toyme is offline
Banned
Re: Re: Re: Re: Help!!!! Big Problem!!! Confused!!!
they said they fixed their clutch problem. maybe it work for them but may not work for your car. i guess it depends on what kind of car.
anyway, what root problem are you talking about and where to find them? i am interested to know because i also have a little problem on my clutch.
Old 03-02-2005, 04:13 PM
whtteg's Avatar
Re: Re: Re: Re: Re: Help!!!! Big Problem!!! Confused!!!
What I was tring to get at is that there is something that is causing the clutch to have the problem. Now instead of modifing another part, just find the actual problem and fix that. And I can't tell you what the "root" problem is because I am not there to actually look at it. But I can tell you that the flywheel thickness is not the problem, maybe they put an aftermarket clutch kit in and the pressure plate is too deep. Maybe they bought just a clutch disk and did not replace the pressure plate. There are many things that could have cause it.
What kind of problems are you having with your clutch?
Old 03-04-2005, 03:04 PM
Haipong's Avatar
Haipong Haipong is offline
Banned
i talked to some transmission shop thats been around over 30 years and they said some flywheels are made just like ludegurls flywheel. also they said its an old school drag racing trick.
Old 03-04-2005, 11:09 PM
whtteg's Avatar
Yes that may be but the fact is that you are still fixing the problem without finding what is really wrong with the car.
Old 03-11-2005, 11:14 AM
predude predude is offline
Re: Re: Re: Re: Re: Re: Help!!!! Big Problem!!! Confused!!!
Ludegurl,
can you please email me at [email protected] i just got a question about a M2F4 tranny. thanks
predude
My 1st Gen Prelude
Mods: Turbonics Turbo, NOS, MSD, DFI ECU
