#16
Re: Camaro will not start
It's not opti-spark either, it has coil packs, and I don't believe it's TBI either, but I'm not sure on that...
#17
i was wondering could it be the ignition coil
#18
i pulled the gas line apart where it turns from metal to rubber towards the front of the car after the fuel filter and turned the key and i heard the pump kick on and fuel shot out of the lines so i dont think it is the pump or the filter and i tried the starting fluid and it didnt work but the other day when i tried to start it it actually started but ran for about 10 sec and stalled and it wouldnt start back up. it just keeps turning over and catches every once in a while and it sounds like it wants to start.
#19
So it fires every once in a while is that what you mean by "catches"? It could be a bad coil pack but I would think if only one is bad it would run but very badly. I dunno though. Did you check for spark on all the plugs?
#20
that is what i meant it fires every once in a while and i did not check all the spark plugs for spark. should i take out the coil pack and have it tested or would checking all the plugs for spark tell me if that is bad
#21
Well if it runs for 10 sec, then it would have died if it was the coil becuase there are alot of revolutions in 10 sec and it prolly just would have died in the first 3 or 4 sec. Id check the injectors they are prolly gummed. Get some injector cleaner and some stabalizer and should be fine.
#22
Ok, well Check for spark on each wire if you can. I wouldn't think it would be the injectors and if they are gummed up so bad that the car won't even run cleaner and stabilizer won't help. If they are that bad you'll probably have to have them cleaned professionally. However if you have no spark on some wires it could very well be a coil pack, make sure you check the wires very well first though better to replace one of those if they are the problem before you spend a lot on a coil pack.
#23
I was talking about after he got injectors cleaned to store with stabilizer. And about injector cleaners they use acids that break down particals fast so if it is getting a bit of fuel to run for 10 sec then it should be long enough to get it working.
#24
Re: Re: Camaro will not start
http://www.automotiveforums.com/vbul...d.php?t=368447 Hopefully we can figure this one out! Let me know if you look at the injectos or not.. I am thinking of doing the same thing next. Unfortunately the fuel Pressure regulator is monted to the rail with a special screw. If you have not checked the regulator pull the vacum and see if gass is leaking from regulator etc... I am still tring to trouble shoot mine so let us know what you find. |
#25
dont know anything about this type of ignition but ive worked on 3 diff. cars that were getting fuel and spark but still wouldnt run, these had bad pickup coils. does this ignition have anything similar ?????
#26
i took the coil pack and ignition control module in to be tested and they passed the test then the guy who tested them told me to try changing the spark plugs so i bought some and replaced them and it fired right up but it runs really bad could this be because of it sitting for a while
#27
after changing the plugs it started right up but it ran like crap then it burnt up the plugs so i replaced them again and now it wont start it just turns over and while turning over it seems like power is cut for a second and then it makes a clunking noise
