Old 02-11-2005, 09:16 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
I've got a 1948 Tucker cast similarly and of like quality I've been tinkering with over the years. Instead of resin, it was cast in Bondo and all there is is a body with molded in windows, lights etc. Someday I'll finish it... - Mark
Old 02-11-2005, 10:26 AM
008's Avatar
008 008 is offline
Re: Kit problems
Ugh I've seen some bad resin bodies but that Lincoln takes the cake. People still slush-cast? Kudos for trying to release something popular, but could've used a bit more work. What a shame.
Old 02-11-2005, 10:58 AM
mickbench's Avatar
mickbench mickbench is offline
Re: Re: Kit problems
Originally Posted by hirofkd
Oh, c'mon. Tamiya kits are works of art compared to some poorly done resin kits.
I have TKM's Lincoln Mk.VIII, and well...it's like this:
http://www.asahi-net.or.jp/~xr2h-fkd...viii/mk800.htm
It's faster to scratchbuild it instead of fixing this model.
OMG..!! That is so bad, how can anyone even get a decent looking model out of that, nevermind a show winner..!!
I've never seen a model so rough before..!! Good luck to anyone who attempts to build that..!!
Old 02-11-2005, 03:48 PM
Chuck Kourouklis's Avatar
Chuck Kourouklis Chuck Kourouklis is offline
Re: Kit problems
Regarding that Tamiya 1:20 Williams, y'all -
The cowl will fit. It's just warped. All you need to do is heat water to boiling, pull it off the burner, submerge the cowl for 2-5 seconds, and bend it back into shape (before painting, naturally - you may have to adjust the assembly sequence accordingly).
Mine fit like a glove after a few minutes of tweaking.
Old 02-11-2005, 04:29 PM
Chuck,
Were there any other areas on the Williams you came across that needed extra attention? - Mark
Old 02-11-2005, 06:34 PM
Re: Kit problems
Not too many, Mark. Yes, the monocoque is split in two, but the fit is so precise that if you make a glue bead along the seam as the instructions suggest, you will actually fill it. I also found that the nose cone has a nice press fit once the monocoque is together.
The only parts that really bugged me were the front uprights; their fit at the front suspension arm pivots is a bit loose, making for wobbly steering poses. Otherwise, it's reasonably free of temperament as I recall...
Old 02-12-2005, 09:42 AM
Thanks Chuck,
I'll get the kit out today and make some notes for future assembly... - Mark
