Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 02-06-2005, 07:55 PM
GotGrip666's Avatar
GotGrip666 GotGrip666 is offline
Banned
Re: Cyclone intake Manifold
u need a valve spring compressor i think and you have to make one your self or buy one off dsmtuners, i think i saw a couple off there, i dont know what else you need but kevin will probally comment soon and tell you, or jake
  #17
Old 02-06-2005, 07:57 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
i hope you were joking about that last post. if they just "popped out", how in tht hell would your engine run? you can make a "home-made" valve spring compressor. www.vfaq.com shows how but i would just take it to a machine shop and they should be able to do it in 15 minutes for you, although it might cost some $$, at least it will get done right.
95 Talon TSI AWD
97 Eclipse GST
  #18
Old 02-06-2005, 09:01 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
yes i was kidding i know they just dont pop out would the mechanic have one i was going to let him do the head and all I need my car back in one day and I don't have any of the tools to perform the swap
  #19
Old 02-07-2005, 01:01 AM
yeah i would let your mechanic pull out the valves and stuff, he should have the right tools for it.
95 Talon TSI AWD
97 Eclipse GST
  #20
Old 02-08-2005, 01:40 AM
Well i have good news and bad news the bad news is that as i said before the valves are toast there is nothing that could be done for them how the hell do you break one. Good new the head it self is in great condition. More bad news i can't find a gasket for the manifold anywhere so i guess i will have to make one that kinda sucks but it could be worse. Good news the two parts together cost me 60 bucks.
  #21
Old 02-27-2005, 12:37 AM
Alright I now have all of the parts to run the manifold i found a sheet of gasket stuff that can be cut to whatever shape needed. I found the hobbs pressure switch. I couldn't find the vacuum canister but i got a vacuum ball from ford and it is supose to have the same affect as the canister. All of the parts are cheap so that wasn't a problem. It was hard as hell to find them but i figured it out. So tomorrow i will get the 2g head pulled off and monday I will get the 1g head set up for use... So I will soon see how much power this thing adds. I'll try to get it on a dyno and give you some numbers. As of now the car has this on it
cone air filter
flow master muffler
type s bov
autometer boost
autometer a/f
autometer oil pressure
greddy turbo timer
est hp 230-240
boost guage reads 18psi
  #22
Old 02-27-2005, 05:24 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Are you using the stock turbo?
If you are going to look for how much power increase there is you should dyno it before hand instead of guessing that your at 230-240 which even at 18psi it would be the most at the crank you could probably get out of that little T25.
Anyways, when you do get the manifold on you are still going to max out the turbo so the manifold really isnt going to do much for you, maybe make spool up a little faster but its not going to give you any more power unless you have a bigger turbo. Even if you do have a bigger turbo, I have yet to see anyone make a substantial amount of power that makes it worth doing the swap in the first place. You might gain 3-4hp but for the trouble you went thru and the clutter in your engine bay, just isnt worth it IMO.
  #23
Old 02-27-2005, 05:49 PM
I would dyno my car before but its not running right now and the 1g head alone should give me more than 3-4 hp. Especially since the 1g ports are twice the size than the 2g. This clutter that you speak of is 2 parts and there is alot of space to work with so I'm not to worried.
  #24
Old 02-27-2005, 06:09 PM
EclipseRST's Avatar
Banned
What you dont understand is you are already pretty much maxed out on the T25 the way you are right now... So you probably wont see much of an improvement. Also the bigger ports take more time to for air to be compressed in them...
  #25
Old 02-27-2005, 07:10 PM
I see what you mean about being maxed out. But that is the purpose of the cyclone to spool the turbo up faster but when both ports are opened up there will be more air flowing in. Even though i can't push anymore boost My high end power should improve just from the port size difference. But the reason im putting it on is for when i get a bigger turbo i will be able to spool faster. On that site the guy who has it installed with a 16g he makes 5 psi below 2500 rpms I don't. I plan to go bigger than the 16g so I will need the turbo to kick in as quick as possible. I know that have a better exhaust will help that but I need to do the timing belt anyway and its only an extra 300 bucks for the head to be machined so. I was already planning to get a 1g head put on so it set me back 85 for all of the parts
  #26
Old 02-27-2005, 08:44 PM
AngelOfNight 9's Avatar
AngelOfNight 9 AngelOfNight 9 is offline
Re: Re: Cyclone intake Manifold
Originally Posted by EclipseRST
I'd also rather have 4 big ports to flow more air smoothly than 8 small ports and a plennum. Thats just another place for boost leaks!
I just had to quote this.... I agree on that 100% &
(gsxeclipse97) If you're going for something bigger than a 16G and you wan't to cut down on spool time then maybe you should try finding a new ceramic ball bearing Turbo, T3/T4 Hybrid or Custom T04E. Avoid a used one because once it goes they're basically done for.
*91 TSI AWD*
  #27
Old 02-27-2005, 10:32 PM
I wouldn't buy a used turbo but im testing out the cyclone and seeing what it will do on the 2g motor also it will give me more highend from what i have now from you. I know what the 1g intake manifold feels like but i want to see what kind of power it will produce..
  #28
Old 02-27-2005, 10:44 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
you dont understand. it doesnt matter right now what you do to let your engine take in more air. your turbo is still maxed out. the turbo can only flow so much air and the t2small is almost maxed out stock. adding the bigger ports and intake manifold will just lower your horsepower since you are adding more volume that needs filled and pressurized. the only benefit of a cyclone mani is the better spool and mpg on a street car. it actually flows 2cfm less at high rpms then a 1g manifold.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
  #29
Old 02-28-2005, 02:12 AM
I know the cyclone flows less than the 1g manifold at higher rpms, but the will flow more than the 2g manifold will at higher rpms. And thats where i loose most of my power is about 5k and on. I know that is also that is turbo is really small and that is part of the problem... You said that adding more volume will make me loose power right. So if I put the 1g manifold on my car now i would loose more power than if i put the cyclone on because it has 4 big ports instead of the 8 smaller ones. In that case i would be better off wiht the cyclone. That is how its made spool the turbo faster and keep the topend power. What would 2cfm's be to your top end hp? So as small as this turbo is basicly soon as i step on the gas i should be at boost that would mean i would have no lag until i get a bigger turbo...
  #30
Old 02-28-2005, 02:05 PM
EclipseRST's Avatar
Banned
No... Your turbo is you whole problem! There are plenty of people in the 300-400hp range with a all stock 2g motor (Intake mani, head and block) and I know that they dont lose power in the higher RPM range.
Get a different turbo if you want more power... The cyclone isnt going to get it for you!
Closed Thread
