Old 02-03-2005, 01:18 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Re: Ground Control with which shocks?
Pleae use the EDIT function next time so you don't double on posts, it is a lot easier to read otherwise...just write
"EDIT-->"
Please will get it.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 02-03-2005, 04:59 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Re: Ground Control with which shocks?
Originally Posted by BoNkA10
Just checked their site and found them, only thing is it says 95-99 DSM Front Upper Mount (requires 1' longer front spring). Same thing for the rear. 1' longer??
The mount moves the shock up one inch, thats the whole point of it, more travel (and longer shock life). Move the mounting point up one inch, and you need one inch more on the spring. Not exactly rocket science. If you call ground control they will explain it all to you. There will come a time when you have to put the keyboard down and actually call them anyway
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 02-03-2005, 05:11 PM
BoNkA10 BoNkA10 is offline
Send a message via AIM to BoNkA10
If it actually said 1" I would have realized that, but it said 1', which is 1 foot. I kind of figured it was a type, but figured I'd make sure, haha.
Can't magically make a spring grow 1" either, so this is somewhat confusing me. The spring is going to be part of the coilover that I order from them..is it not? I could just have my information all mixed, explaining my confusiong. Heh, sorry if I do.
1998 Eclipse GS
Old 02-03-2005, 05:23 PM
AF - Advisor
You can buy the standard diameter eibach race springs that ground control uses in many lenghts. It would typically be 6 inches. With the upper mounts they will recomend 7" springs. Again, they would gladly explain all this to you when you call
Kevin Jewer
Old 02-03-2005, 05:36 PM
I can order right online you know :-P
But I thought the springs on the coilovers were all I needed? Didn't know I'd have to go and buy springs too.
1998 Eclipse GS
Old 02-03-2005, 05:41 PM
AF - Advisor
They come with the kit! You choose rate and length!
Kevin Jewer
Old 02-03-2005, 05:45 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Only expensive setups like tein and JIC are one piece coilovers.
YOU buy springs and shocks seperately and put them together to make coilovers.
Old 02-03-2005, 06:45 PM
Yeah, I thought they came with the kit. It's just that some people start talking about one thing and immediately switch to something else and when it's read it means something totally different than what they meant.
Only problem I see is if I order online I can only choose the rate, not the length. I'll have to get in touch with them to check all that out tonight.
1998 Eclipse GS
Old 02-03-2005, 11:10 PM
AF - Advisor
Like I said, call the cocksuckers. I have done this before you know.
Kevin Jewer
Old 02-05-2005, 01:41 PM
bighauns's Avatar
