Old 01-24-2005, 10:10 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: I am back!!!! with questions...
i used but crimps, those are fine, its the quick connects that are clamped shut that i see that i would take off and throw as far away as possible, lol wow... i tell ya what, for 500 bucks ide make damn sure all my connections were gold
Old 01-24-2005, 11:27 PM
H4Bangin's Avatar
H4Bangin H4Bangin is offline
Send a message via AIM to H4Bangin
Vtec-E..... z6 block with a vtec-e head? and Si injection
or is it just the valve cover
********** My 94 SS **********
90 civic dx 4 door d16z6 - p28, aem intake, act stage one clutch, cheap header- commuter car
Old 01-24-2005, 11:39 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
thats what my friends dist looked like when he did a z6 swap but kept it obd0. so that it would bolt up right. but his looked positioned different. i would throw a timing light on that and make sure hte timing is good
Team Lonely Drivers
Old 01-25-2005, 06:14 PM
T-Mo's Avatar
T-Mo T-Mo is offline
Send a message via AIM to T-Mo Send a message via MSN to T-Mo
someone on Honda-tech pointed out the valve cover thing. Hopefully its just a change of valve cover. The block says d16z6. thanks for the help so far people!!
'93 Honda Civic EJ2
'90 Civic HB w/ d16z6 swap: SOLD!!!
Old 01-26-2005, 03:38 PM
bambam89lx's Avatar
bambam89lx bambam89lx is offline
AF - Advisor
Send a message via AIM to bambam89lx
that wiring looks like anus. Its absolutely horrendous!
I would think that it's wired wrong just by looking at the pictures you took. it doesn't look like he knew what he was doing. You should trace each wire from the dizzy back to the ecu with a continuity tester or multimeter.
valve cover sucks...lol.
The td 18u is the 88-91 civic/crx si distributor. That distributor isn't supposed to be able to bolt to that head without modification. Can you look on the head and tell me what head code it is? What engine code does it say on the block? Maybe it's a d15z1 head on a z6 block...
it's kinda confusing...
does the distributor legs look modified at all?
Jumper harnesses, mpfi conversions, engine harness conversions, vtec subharnesses, etc.
The absolute lowest prices at the absolute highest quality. Trusted. Guaranteed.
Click the image above to visit our online store!
Hastings Bseries and Dseries piston ring kits (inc. ZC) - $49 shipped
Old 01-26-2005, 04:13 PM
jhmcrx's Avatar
jhmcrx jhmcrx is offline
this probably wont help, on the distibuter there are 2 SOLID white wires, i wired mine backwords the first time it barly started and barly moved, so then i switched them around and its perfect!
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
STD manifold W/adaptor plate
dsm bov
stealthemodeperformance.com oil line's
Tsudo cat back
basic hi flow cat
front tower bar, rear tie bar
short throw shifter
and other small stuff
Old 01-26-2005, 07:18 PM
T-Mo's Avatar
thanks for the help everyone. We solved them problem today. #3 cylinder wasn't firing because the injector was bad. Got 4 injectors (only needed 1) from the junkyard and everything is running fine.
As far as wiring everything is cool. He and a friend must have done the bootlegging trying to figure it out, because the rest of the wiring is soldered and everything. Just on that distributor part is where it is looking bad.
We had to change the oil because the injector was sticking open, i guess, causing it to flood. The oil was thin as water too.
'93 Honda Civic EJ2
Old 01-26-2005, 08:38 PM
jhmcrx's Avatar
hm interesting..well at least you figured it out!
1988 CRX DX
MODS:
Garrett T28 turbo
450cc DSM injectors
TurboEdit
dsm bov
Tsudo cat back
basic hi flow cat
short throw shifter
