#16
Re: Chevy Colorado Issues
#18
I purchased an 05 Colorado at the end of 04. Its my first brand new vechicle and I also have had nothing but problems. The most recent is the check engine light came on resulting from loss of compression in one of the cylinders. My truck is just out of manufactorers warranty and into extended warranty (40k). It's been at the dealer since 1/9 and today they informed me that the cylinder head that I have been waiting on is non existent. They don't have a part for it nor can they find one so I have to sit back and wait, while I have no transportation and am paying a note on something I can't drive. Any advice?
Thanks! |
#20
I've noticed them in the atlanta area get some friends and relatives and they carry picket signs telling about the dealer. They do this on a weekend morning when a lot of customers are looking. Some people get an old car painted lemon yellow and park it out front.
Depending on your phone company rates start calling big dealerships hunting the part. Also use the internet. You can even call junk yards for a used part send it to a machine shop for a valve job,pressure test and shaved. Depending on you engine size surely a head is available. |
#21
Wow...I have a 2004 Colorado...I haven't had any problems with it...just the recall on the brake light switch....
#22
Yes colorodos are trouble, i have a 2004 z71 and its been trouble since i bought it. Within the first 10000 miles an ignition module burnt out then 2 months later the radio burnt out, then on 15000 miles the o2 censor whent out.Then 2000 miles later the o2 censor whent out again. Now my problem is the anti theft system, the security switch in the ignition is fowled out wich cuts the fuel system off when you try to start it up. So when i get it fixed chevy and stick it and im tradeing it in, if anyone would be dumb enough to take it hahaha
#23
I have a 04 Colorado with 28k miles. The front turn signal socket ate lamps until I figured out the problem. The new baseless lamps are CHEAP, no other reason for their use.
My heat/AC blower stopped working except in high speed. Most posts on the subject imply a failed resistor. In my Colorado, NOT the case. Those GM "engineers?" have the blower wiring harness hanging down into the passenger foot well. It gets kicked and I had to unplug and replug to solve the problem. It will probably work until kicked again. The armrests are "loose" and squeek when pulling the door shut or operating the PWs. In general; No real serious problems but the Colorado is a CHEAP, CHEAP truck! Never another GM vehicle for me, hello Toyota! |
#24
woody, same problem here with my 04 4x4 Colorado. The heater/AC only works part of the time. When we were on a trip, I stretched my leg out sorta under the dash and the heater started blowing again.
I haven't had any real serious problems yet. Occasionally, if I am sitting at a stop sign, the brakes will slowly go to the floor, and sometimes my ABS light come on for a minute. My son is trying to change my front breaks now, but the hub wont come off. Anyone know whats holding it on there? We even got a hub puller and it wont budge |
#25
I haven't worked on a Colorado but the brake pedal going to the floor usually indicates the master cylinder is bypassing internally.
On some front hubs you need a slide hammer to remove them. But I found them on a Honda not a U.S. vehicle but they may have changed. |
#26
Thanks rhandwor, The brakes only did that a couple times and not for a long while. I've had the truck since August 2006 and really haven't had any big issues with it. Maybe the guy that owned it before me got all the bugs worked out already lol I just bought a Hanes repair manual so maybe we can figure out that Hub system. I was told its like the Toyotas. The garage wanted $780.00 to put new brakes on because of the front hubs. I about passed out. My son will be doing it for me. Anyway, I do appreciate your reply and I'll tell him to check that master cylinder
#27
The front rotors on the Colorado is a captured-rotor set-up. There are 6 bolts holding it on and its also pressed onto the hub. It's much easier to turn the rotors while still attached to the truck if they are still in good shape. The pads themselves only take 10 minutes to replace.
For the HVAC, the fan motor resistor is most likely the culprit. I listed the parts nedded in this thread: http://www.automotiveforums.com/vbul...d.php?t=877307
Thanks DBNissan,
Is there any way to get that hub off so I don't have to pay the garage $700 to fix it? I bought new rotors and Bindex pads for it already. The rotors show some wear and I would prefer to put new ones on it with the new ceramic pads. |
#29
Nope, it wasn't in the Hanes manual. It was sealed in plastic so no pages ripped out lol
I'll pm you my e-mail, I appreciate the help. Thanks so much !!! |
