Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 01-11-2005, 11:48 PM
streetrcr45's Avatar
streetrcr45 streetrcr45 is offline
Re: Racing/engine tips needed!
o ya..i like the fact that your name is
"Yamahapower" Yet you have an American Car in your sig, none the less a Mach 1. i think thats funny
sorry for the double post... but i'm too lazy to edit
DIE TRYIN
FORGIVE BUT NEVER FORGET
Old 01-11-2005, 11:59 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Re: Re: Racing/engine tips needed!
His old ride was a SHO... which was powered by a Yamaha designed V6 I believe.
Thus, Yamaha Power.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 01-13-2005, 08:25 AM
2kCivic_GSR's Avatar
2kCivic_GSR 2kCivic_GSR is offline
would running a dyno test be a good way to decipher the problem? I'm starting to think about just swapping back in my EX motor and rebuilding the B18 c1, because im starting to think it may be an internal problem? Im also thinking that the previous owner may have done something to the engine as well? should i run a dyno test first? or just rebuild the engine? thanks for all the replies.
Old 01-13-2005, 09:53 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Why do a dyno run if you're going to completely overhaul the engine? Rebuild it first
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 01-13-2005, 11:28 AM
I don't know i thought running a dyno would save me time in rebuilding it? but oh well....rebuilding it would be alot more fun anyways. thanks everyone for your help.
Old 01-13-2005, 11:33 AM
10sec-Hopeful 10sec-Hopeful is offline
First off, unless you are shifting at like 3000RPMs, VTEC should engage around 5500...if not, check your spark plugs. I used to have a 93 GSR with a B18C1 and I had a cracked plug. When I fixed that, boy did she jump on the stick. Word of advice - get higher fuel injectors as Josh said...will help out a lot. Other than that, not sure.
I'm heading out to work today, I can check it out there for ya (couple guys have B-series engines).
-Later
Old 01-13-2005, 12:13 PM
Re: Re: Re: Racing/engine tips needed!
Thus, Yamaha Power.
i'll shut up than
DIE TRYIN
