#16
Re: lowered 95
blazerlt,
Have you left your 4x4 lowered? Did you lower it just to see what it would look like? Cubanlorenzo, I've heard you can crank the tbars enought to fit zr2 wheel in there if you want. This isn't too good for your balljoints, but you can get the moog ones -they last a lot longer. Remember you also have to shackle or block the rear too. |
#17
Re: lowered 95
i just had all 4 of my ball joints replaced. they were the stock balljoints with 185000 miles on them. just had them replaced 2500 miles ago. not looking to buy new ones. id rather leave my blazer at stock height then shorten the life of them by lowering my blazer. thanks anyway
#18
Re: lowered 95
You can remove the bolts totally for a maximum drop.
The more you turn the bolts out, the more the front end will drop.
1995 Factory Blazer Service Manual for sale, PM if interested. |
#19
Re: lowered 95
if i were to buy the blocks for the rear and turn down the torsion bars, would i get any worse/better or a ride? i like the look of it lowered a bit
#20
Re: lowered 95
The ride with soften up a bit. Nothing big though.
#21
Re: lowered 95
think it is worth doing?
#22
Re: lowered 95
Sure, if you want a drop for cheap.
I'm going to be redoing mine soon. Just be mindful that you will have to go in for an alignment soon afterwards.
#23
Re: lowered 95
i need an alignment anyways, little off. i think i might go with the drop then. you said 3" total dropped? should i go the full 3" or maybe 2"?
#24
Re: lowered 95
That depends on how much you rear end is sagging.
#25
Re: lowered 95
i dont think it is sagging at all. thinking more about it. i dont think that i will do it. i have a hitch under my bumber and with lowering it 3 inches will make it even lower to the floor. that, and not too sure i want a lowered truck. i live in northern jersey and the damn mountains and snow around here suck. thanks though
#26
Re: Re: lowered 95
