Old 02-02-2005, 03:55 PM
red94fourdoor red94fourdoor is offline
Send a message via AIM to red94fourdoor
Re: More 4x4 problems
e-mail sent
Old 02-16-2005, 02:40 PM
Warlok Warlok is offline
BlazerLT...where is the 4wd relay on a 94 Blazer 4x4? I can't see one behind the glove box or under the dash in that area. There is one under the hood on the pass side firewall...could that be it? As always, thanks for the help.
Old 02-16-2005, 02:43 PM
BlazerLT...where is the 4wd relay on a 94 Blazer? I can't see one behind the glove box or under the dash in that area. There is one under the hood on the pass side firewall...could that be it?
Old 02-16-2005, 03:12 PM
Fireplug Fireplug is offline
Is ok if I answer your question???
Look at your ecm it should be mounted on a bracket on the ecm
TCCM is what you are looking for ???
Old 02-16-2005, 04:05 PM
Sure, it's okay. Thanks for the reply. I'm not sure where the ecm or the tccm is on this vehicle. When the 4wd tries to work I hear a clicking from the pass side, but can't find anything. Lately, I can only get the 4wd switch to do anything is by moving the veh back and forth in the driveway. Tried the battery trick...no joy.
Old 02-20-2005, 09:06 AM
Help, My front driveshaft spins but the wheels do not Any Ideas is the front diff stuck?
Old 10-10-2005, 02:44 PM
Re: Re: More 4x4 problems
Originally Posted by Hunter1
I have a lot of good parts left over that I didn't need. sort of the trial and error thing. If you can email a list of parts that you need I will try to locate them. [email protected]
Do you still have these parts? I still haven't fixed my issue with my 94.
Old 10-13-2005, 09:35 PM
Hunter1 Hunter1 is offline
I think I still have a control modual. What were you looking for?
Old 10-13-2005, 10:56 PM
I will have to run the error codes when I can get a chance to. It has been raining here since monday. Either a TCCM or an encoder motor. Do you have any or can you take some pics of these parts? So I know what I am looking for
Old 10-17-2005, 01:38 PM
Checked the error codes from the ALDL connector. I got 2 flashes from the 4WD switch. I it is a bad encoder motor. Thanks for all the help. I will have to order one now. I will let you guys know what happens.
