Old 12-30-2004, 09:39 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
Re: greddy type s
no i think I'll just wait untill i can get the piping i want so i don't have to install it more than i need to. There and 2 vac lines on that bov and i only have one on the stock so where is the smaller one going to go?
Old 12-30-2004, 09:56 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: greddy type s
You dont need to hook that up but if you want you can hook it up to the turbo outlet or an IC pipe and what it does is it helps the BOV respond and release faster...
Most people use them if you cant get the BOV soft enough, like you have the screw all the way out but yet the spring is still to stiff!
Old 01-01-2005, 02:34 PM
Re: greddy type s
wouldn't that make the car jerk more if it release to quick? When i removed the dump tube from the stock bov and drove it was pretty harsh. I put a 3 liter bottle cap on the end and clamped it down with 2 holes and i made it much easier to switch gears. but now it sounds like the ssq from hks
Old 01-01-2005, 03:31 PM
EclipseRST's Avatar
Banned
Re: greddy type s
You put a bottle cap on the outlet of the BOV?
Put your dump tube back on! There is a reason its there in the first place, the reason your car is running shitty is because you are venting!
Old 01-01-2005, 06:57 PM
Re: greddy type s
I'll try it but it jerks really hard when i have it on almost like when you hit fuel cut, but that is only when i switch gears. Well i just went out and tested it out i made my car slower, it only pushes 14 psi instead of 16. I don't think that I need it on there.
Old 01-04-2005, 05:22 PM
FoRCedInDuKsionGsT FoRCedInDuKsionGsT is offline
Re: greddy type s
actually i haven't done a boost leak test but it dont seem to leak for me...and my 1g flange is actually metal so i didn't have any problems drilling holes in them....i forgot, you gotta 97 they dont come in metal. My bad dawg...
Old 01-04-2005, 10:31 PM
Re: greddy type s
I think that i will be getting the piping soon so Ill be alright. Do you know why my boost level droped when i put the dupe tube on i went from 16 psi to 14
Old 03-13-2005, 12:09 AM
silver98GST silver98GST is offline
Re: Re: greddy type s
Hey guys,
Didn't want to start a new thread, so thought I'd post here. After reading that I would need a flange and adapter kit to make the greddy type S bov fit on my stock UICP and from the advice of Jake and others in this forum about replacing the UICP, I've decided to buy the greddy type S bov and new UICP. I found an intercooler piping kit on ebay which is flanged for the greddy type s (link here )
I have the stock SMIC in my car. Do you guys think that ebay pipe kit will work or should I go with dejontool or something else? The ebay one seems to be the best value and it doesn't seem like there's much of difference in these pipes compared to the other brand name ones except the price. I e-mailed the seller and he says "the 90degree pipe is about 3", the rest two is about 2.3".
Replacing the intercooler pipes doesn't look too difficult. How long did it take you guys to replace them?
1998 Eclipse GST AT
Mods: FP intake pipe, K&N filter, MBC, Glowshift pillar pod w/ tinted gauges (boost, A/F, oil temp gauges), Blitz DTT DC2 turbo timer, Greddy Type S BOV, Apexi N1 exhaust, Megan downpipe, Dejontool blow thru UICP, GM MAFT, Denso 660cc injectors, ARP headstuds, 3000gt sl big brake upgrade, Eprom ecu, DSMlink V2, etc.
Come visit my cardomain page!
Old 03-13-2005, 02:48 AM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: greddy type s
That ebay pipe doesn't seem like that much of a bargain. There is a guy named Brode that makes them, which I have in one of my cars. In the other, I'm using an RRE upper pipe.. and of course, dejon tool is another great company. The brode piece is only, what, $80?
Old 03-14-2005, 02:31 PM
Contacted Dave Brode yesterday and he said he doesn't make the entire UICP (no "S" pipe). He charges $76 shipped for the lower portion of the UICP and I think $8 for a flange to adapt to the greddy type S. The ebay one is for the entire UICP. I'm checking the dejontool and rre pipes to see what the price difference is. Been hearing a few bad experiences from other with the ebay pipes. Is anyone here using them?
1998 Eclipse GST AT
Old 03-14-2005, 03:05 PM
BoostedSpyder's Avatar
BoostedSpyder BoostedSpyder is offline
Send a message via MSN to BoostedSpyder Send a message via Yahoo to BoostedSpyder
Re: greddy type s
be like me and spend way too much on the greddy pipes
Old 03-14-2005, 03:30 PM
george536's Avatar
george536 george536 is offline
vince loves his greddy
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
