| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
| View Poll Results: What kind of oil do you used | |||
| Syntetic oil |
33 | 70.21% |
| Semi-syntetic oil |
2 | 4.26% |
| Mineral base oil |
12 | 25.53% |
| Voters: 47. You may not vote on this poll | |||
#16
Mobil 1 synthetic and nothing else.
#17
before i only use mobil 1 but now i'm using the honda VTEC oil, both very good oil
Original PureHonda Member JDM hybrid B18c EK sedan & EG Hatchback SiR Click here for Pictures |
#18
) dissertation on this one. I wonder if it's still here. Btw, fritz: if you're around, please give your 2 cents' worth on my query about Splitfire's new triple platinum. I need to replace my plugs soon. Thanks man. Sorry, off-subject there. I've always used Mobil 1.
#19
Castrol Syntec 10W30 in my '98 Prelude SH
and Castrol GTX 20W50 in my '64 El Camino. Demonic - Castrol sells both "Syntec" which is a full synthetic (although not a PAO base), and "Syntec Blend" which is something like a 50/50 mix. Most oil questions will be answered at these two sites: Oil Bible: http://www.fernblatt.com/longhurst/engineoil_bible.html Oil FAQ: http://auto.msk.ru/auto/ehoilfaq.htm
#20
The best way to flush is with a specifically formulated "flushing oil". Most petrol companies make some version, but you rarely see it in your local auto parts store.
You could flush with just a low weight synthetic (like 0W20) oil, but that doesn't have the solvents that a flushing oil does, so it would be drastically less effective and not really much cheaper. The quick and cheap way to flush is to add a concentrated solvent to your existing oil and just run your engine at a fast idle for around 5-15 minutes. Then drain it immediately. http://www.autobarn.net/chmf-3.html ($2.69) http://www.guarding-our-earth.com/amsoil/flush.shtml ($4.75) And if you switch to synthetic, do change it out after the first 3000 miles no matter what the manufacturer claims. After that point, you can go longer between changes if you like. But for rybred, with 110,000 miles, I'd probably just stick to a good mineral oil like Castrol GTX. Re-read this quote from the engine oil bible: Quote:
#22
fritz, i've switched to synthetic about 1 year ago when i had approx. 135,000kms...i'm now at 157,000kms...i don't know what that is in miles...i guess it's about 100,000...but i regularly change my oil every 5000kms...so do you still think it's a bad idea to flush my engine with the amount of km's i have on my engine?? If you know?...what am i mainly cleaning out when i flush my engine?...cause i did get all my valves and head cleaned when i bent those valves! sorry to go on and on about this subject, i just want to make sure i don't f#@k up my engine! thanks!
#23
I used to use Mobile 1 then I switched to Castrol GTX.
#24
I wouldn't do a flush. It would just be a waste of money.
#25
Mobil one tri synthetic
Spend money now than later :silly2:
:evillaugh My bitch is a red headed 1998 honda civic hb. |
#27
I use Mobil 1 tri synthitec that shit works good.
1989 s13 Fastback Tein HE coil-overs sr20det swapped! JIC Magic Front and Rear Strut Bars Slotted and Cross-drilled Rotors S/S Brake Lines Pivot Lazy eye controller Blitz LM Intake Blitz D1 Spec Turbo Timer Soon to come: Sard 550cc Injectors Blitz Nur Spec Exhaust Blitz Down pipe HKS FMIC http://www.driftmonkey.com (Part Owner) |
#28
until reading this post i was gonna switch to synthetic....... i guess i shouldn't now, it sounds like a huge process, flushing etc, and not really recommended
---1996 Black Acura Integra---- Integra Type R Front Lip Spoiler Autometer 5" SportComp Silver Tach w/Lite Autometer Full dual pod pillar with A/F and Water Temp. Gauges 5Zigen Fireball Exhaust AEM Cold Air Intake DC Sports 4-2-1 Header Eibach Sportlines Tokico Blue Shocks DC Sports Short Shifter Strut Tower Bar Titinium ITR Knob 98+ OEM taillights Momo Pedals Sony 700 Series CD/MD shipping.... WW RS sides and rear |
#29
I use Mobil 1 synthetic 15-50. Works very well.
1993 rx7 1994 Civic Ex |
#30
Read this. http://www.leecao.com/honda/vtec/dohcvtec.html |
