Old 12-21-2004, 08:14 PM
stfuad's Avatar
stfuad stfuad is offline
Send a message via AIM to stfuad
Re: resons it doest want to move?
what year is the car? You might want to take it to an autozone or somewhere where they can check OBD2 codes.
Car might be in limp mode.
check your idle set screw. it sould be on the back of the intake manifold, maybe, dunno, it is on a 240sx :P it should be a flat head screw.
Goto a mechanic.
Old 12-21-2004, 09:04 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Re: resons it doest want to move?
The idle screw in on the TB itself. If its revs slow it sounds like your MAS is unplugged.
Old 12-21-2004, 09:27 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
an unplugged MAS would cause the idle rev to fluctuate. it will rev up to about 1500 then down to around 500, then possibly die. but definitely check to see if the MAS is unplugged.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 12-22-2004, 02:43 PM
crazy_quick crazy_quick is offline
My mass air flow senser is plugged in and it still does it.
Old 12-23-2004, 01:25 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
it doesnt misfire??? just low idle. sounds like you may have a massive vacuum leak. make sure you didnt accidentally disconnect any vacuum hoses???
try cleaing the harness to the MAS....
did you check the fuel filter to see if it was facing the correct direction?
check the throttle position sensor???
check the fuel pressure?
try disconnecting the battery cables to reset the computer...
ZedEx Crew Member #4
Old 12-23-2004, 07:37 AM
stfuad's Avatar
Or go see a mechanic... they'll find out what's wrong...
