Old 12-12-2004, 01:12 PM
Canabalooza Canabalooza is offline
Re: weird problem
k so i was changing some filters out and i put my finger on the wire by the rubber which is cracked and it zapped me. its leaking huh? or maybe its not but if it is i need new wires
Old 12-12-2004, 01:37 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: weird problem
what wire is this that shocked you ?
Team Lonely Drivers
Old 12-12-2004, 07:32 PM
Re: weird problem
one of my plug wires around the rubber part that goes on the plug its cracked and i touched it and it zapped me my dad said thats usual because i was grounded and its only rubber.
Old 12-13-2004, 04:48 PM
Randy_che Randy_che is offline
If your plug wires are cracked and you are getting zapped when you touch them, it is time for some new wires.
Old 12-14-2004, 07:16 PM
Re: weird problem
k i have another problem i changed my plugs to +2 bosch platinums and didnt change the wires a (they are on order) now my car sputters real bad and i went from 350 to 400 miles on a tank to 180ish. also it smells pritty bad. i have my o2 light on but when the cel does come on it sputters less i think.... not sure maybe its in my head. the question is first one of my plug end into my dizzy scraped when you wiggle it... hard to explain but is it a bad wire? im guessing so. next can i and how do i rewire my o2 sensor changed it out 4 times now and no luck. got the connector one tried it no luck got it replaced no luck got the splice one tried it no luck tried to rewire my connector still no luck. can i goto home depot and get some wire and splice an o2 sensor to it and run it to where ever it goes? and where does it go? one last thing the cel only comes on when i let my car decelerate in gear if i put it in neutral and break it dosent come on. only when the engine is decelerating the car. any ideas?
Old 12-14-2004, 07:22 PM
cloneboy17's Avatar
cloneboy17 cloneboy17 is offline
Re: weird problem
i think i have some plug wires around here somewhere if you want em
i replaced mine a while back and didnt need to... ill send em to ya for 5 bucks plus shipping
Old 12-14-2004, 07:25 PM
Re: weird problem
i ordered some off ebay payed like 25 bucks for some obx red ones shipped so thats not the issue unless thye are retarded in that case i might take you up on the offer after i find out.
Old 12-21-2004, 11:34 PM
Re: weird problem
k so i changed my plugs it sputtered changed my wires it sputters it smells like gas really bad and im loosing gas mileage. still dont know if i can re-wire my o2 sensor.
