Old 12-05-2004, 11:34 AM
thunder-phantom thunder-phantom is offline
Re: Re: Re: engine just dies after 20 min
fuel pressure is 58 constant running or after it dies
Old 12-05-2004, 03:09 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
hmmm, should be 61-64 while running......I've seen worse though. When it's running how does the oil pressure look?
Old 12-05-2004, 03:50 PM
oil pressure good 40 + always
Old 12-05-2004, 07:42 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Originally Posted by thunder-phantom
good 40 + always
No, not on a CPI. Even 45-50psi will have the truck not starting.
The poppets require at least 55 psi to open properly.
On a 1993 Vin W, the pressure should be 55-61 psi with the key on and the engine off.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-07-2004, 07:32 AM
Lobo1 Lobo1 is offline
Check engine coolant temp sensor. I heard that this is very common for the "engine dies when warm" condition, but I have no personal experience with the problem. Cheap & easy to try.
Old 12-07-2004, 10:57 AM
BlazerLT's Avatar
AF -Advisor
Nah, throwing random parts at a truck is not a good idea.
Old 12-07-2004, 11:23 AM
gbic1 gbic1 is offline
THis sounds familer. Did you check the plugs to see if flooded? Have you pulled off the plenum to see if it is flooded up there again? Where did you get your cpi unit?
Old 12-07-2004, 07:15 PM
cpi unit is ac delco
Old 12-12-2004, 07:35 PM
Well After A Month Of Playing With This Thing And Replacing Fuel Pump,cpi,ecm,plugs,wires,cap And Rotor, Today Put In A Ignition Module And Its Running....it Had Spark The Hole Time But Must Have Not Been Enough................thanks For All The Help
Old 12-12-2004, 07:48 PM
rlith's Avatar
Good to hear it!!! (Didn't I mention that in the 3rd message in this thread? (grin, just jagging ya) Glad it's all good.
BlazerLT's Avatar
AF -Advisor
I Get A Kick Out Of People That Use Capitals At The Start Of Every Word They Type. Makes Me Horny....
