Go Back   Automotive Forums Car Chat > Car Comparisons
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :)
View Poll Results: Which do you like best?
2001 Acura Integra Type R 16 53.33%
2002 Acura RSX Type S 9 30.00%
2001 Honda Prelude Type SH 4 13.33%
2003 Hyundai Tiburon GT V6 0 0%
2003 Mitsubishi Eclipse GTS 1 3.33%
2002 Toyota Celica GTS 2 6.67%
Other 2 6.67%
Multiple Choice Poll. Voters: 30. You may not vote on this poll
Old 12-02-2004, 10:03 PM
S2CorollaR S2CorollaR is offline
Send a message via AIM to S2CorollaR
Re: Asian FWD Coupe Battle
I'd go with the Type R simply because the 2002 Celica GTS was very weak compared to the 2000-2001. It had a premature rev limiter, lowering it's ETA for the 1/4 to 15.4-15.5....
The 2000 Model Celica GTS actually beat out the 2001 type R in some tests and was rated as one of the fastest FWD cars of its time.
If the Integra Type R was so great, why'd they drop it when toyota put out the ZZ231?
I don't know... While I agree that the Integra is more sport oriented, the Celica has lighter weight and a closer geared transmission, so with the right aftermarket support I'm sure it'd bring more than just regular heat to the Integra Type R's doorstep.
Sonny
Old 12-03-2004, 12:13 PM
TatII TatII is offline
closer gear ratio? not true.
all GT-S's gears are spread apart from 1-2. whenever you shift from 1st to 2nd it falls out of the vvt range. they did this becasue they needed 2nd to be tall enough to hit 60. this is becasue toyota feared that the typical magazine writer cannot do a 2-3 shift fast enough so it would hurt the 1/4 mile time.
i find that kinda gay if you ask me. you have to deal with the engine falling on its face everytime i do a 1-2 shift.
also the only thing the celica have over the type R is weight. and that is because its on a newer platform. it has no LSD either.
why did acura drop the type R? i have no clue. it was always a limited production car anyways so it wasn't offered every year. when the GT-S came out, the Type R swept it. then a year later. they stoped production, and a year after that the RSX-S took its place and still took the GT-S out.
303whp stock internal KA-T
94 Acura NSX
Best E.T. 13.559
Best Trap speed 107.62 mph
Old 12-03-2004, 02:10 PM
Strange considering the GTS outhandles the Type S any day of the week, with any driver. The 2000 GTS also dropped right into lift because it was the only year before the latest 2004/5 models that had the 8300RPM redline, instead of the 7800RPM redline that the 2002+'s had.
In fact, one of the only things noted about the 2000-2001 model was the fact that it was the best one for lift shifting. You take it to even 8200RPM and if you shifted perfectly, you were right above the lift mark.
Sonny
Old 12-03-2004, 02:14 PM
Oh and btw, the RSX Type S came out in 2002, the same year that Toyota shafted the Celica GTS's power train.
Put a 2002 RSX Type S against a 2000 Celica GTS and you'll find that the results won't be the same.
In fact, in Sport Compact Car they even said that if the Celica GTS didn't have the "glitchy redline" it would've taken the RSX type S. Why? Because the 2000 Celica GTS was just as fast, straight line as the Integra Type R. It ran 14.8 in stock trim. .2 seconds faster than the stock Type S ran, and it was also about 450 pounds lighter with only a 20HP loss in power comparison.
Stock for stock, I'd put my money on a 2000-2001 GTS.
If you're a modder, then yeah, RSX S is the way and the truth, because for some strange reason, the aftermarket support for the GTS is about as common as Nick Carter fans.
Sonny
Old 12-03-2004, 03:06 PM
MexSiR's Avatar
MexSiR MexSiR is offline
Send a message via MSN to MexSiR
Im a Nick Carter fan! Yay!
Honda Civic 1999 EBP SiR
Im not as fast as I am furious.
1/4 mile = 15.347 (sealevel)
Porsche RS America
BMW 323 01
Pictures of my ride (Pictures)
Old 12-03-2004, 05:51 PM
very interesting indeed. so you can compensate for the fall off powerband is to rev past redline.
and you know i never noticed that coincidence with the RSX type S. but its does make sense too.
94 Acura NSX
Best E.T. 13.559
Old 12-03-2004, 07:39 PM
Actually yeah... It really sucks but the GTS is a very strangely powered car.
It has a very spikey power band that requires you to land it in 6000 RPM when you shift, otherwise you drop power. The year the Type S came out, Toyota suddenly dropped the GTS' redline to 7800 RPM, making it virtually impossible to keep it in peak power when you shifted. The RSX Type S on the other hand gains peak power at what, 6000 RPM? Yeah the GTS needs a crazy driver to compensate the fall off of power, which is probably why they lowered the red line. A lot of 2ZZGE engines were being replaced from warranty.
Sonny
Old 12-04-2004, 09:14 PM
15poundhead 15poundhead is offline
Type R, but RSX S by default
I agree the Type R would be the best car on ur list, but they are hard to come by, at least here on the East Coast. A RSx-S is the next best thing, and they are easy to come by. just go to ur local carmax
Old 01-17-2005, 10:00 PM
Master Hiko's Avatar
Master Hiko Master Hiko is offline
Re: Re: Asian FWD Coupe Battle
Originally Posted by Dave1669
True, the Eclipse is technically an American car. What I should have said is FWD coupes from Asian car manufacturers. And every car I have listed is an American model (Acura Integra instead of Honda Integra, Prelude SH instead of Prelude S, etc.)
the Prelude S is a totally different car from the SH, but im sure you meant Type S. and no prelude was ever made in america, thats part of the reason for the car getting dropped, it had a bad turnaround price from importing it. neways, for styling id pick the prelude, for the engine id pick the prelude, but just because of the weight, the ITR is my second pick. remember, you said overall not just performance and i think the lude has got the total package.
Me>>>you.....n00b
Old 01-17-2005, 10:20 PM
3kgt8's Avatar
3kgt8 3kgt8 is offline
Re: Re: Re: Asian FWD Coupe Battle
Originally Posted by Layla's Keeper
Yep, and the first Eclipse built without Chrysler influence.
Hmm.....
Eclipse with Chrysler - 2.0L turbo four AWD maniacal sports coupe with rally and autocross wins and a reputation for durability and power amongst tuners.
Eclipse without Chrysler - V6 powered coupe with a reputation for breaking down and being girly.
Who'd have thunk it. It took American know-how to make a great Japanese coupe.
im not sure what you mean by breaking down, because the 3g eclipse is the most reliable of all the eclipses, and im pretty sure ive seen more girls driving the 2g than the 3g. Well thats here in Texas.
Old 01-17-2005, 10:44 PM
[quote=Layla's Keeper]Yep, and the first Eclipse built without Chrysler influence.
Hmm.....
Eclipse without Chrysler - V6 powered coupe with a reputation for breaking down and being girly.[quote]
IIRC, that engine was developed prior to the merger (so to speak) so if you ask me, chrysler piggy backed on a great engine built by mitsu and got pretty far riding their coat-tails. and yes the new eclipses suck, as do all other mitsus right now but that has nothing to do with chrysler not being involved.
Me>>>you.....n00b
Old 01-18-2005, 03:35 AM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
They didn't, Honda simply changed the name in the US market when the new model came out. Every where else in the world you can still buy a Type R Integra, and its faster then the previous one.
Old 01-18-2005, 05:19 AM
Jimster's Avatar
Jimster Jimster is offline
Here for the pussy, man.
Send a message via ICQ to Jimster Send a message via AIM to Jimster Send a message via Yahoo to Jimster
And IIRC, the RSX Type S is just a bespoilered JDM Type R with cushier suspension, a lower Compression ratio, comfier Recaro's and no Brembo's.
As for the comparison, only one of these cars was built with motorsport in mind, I think we all know which one it is (DC2 Integra Type R)
Check out my Pride and joy in AF- and discuss your favourite Alfa Romeo
2007 Audi A4 3.0 TDI Le Mans
Old 01-22-2005, 01:48 PM
crayzayjay's Avatar
crayzayjay crayzayjay is offline
CFA
For fucks sake.
10-day limits on polls please.
I have a 993
This is not 'Nam, this is AF. There are rules.
Old 01-22-2005, 02:40 PM
TRD2000's Avatar
TRD2000 TRD2000 is offline
i was wondering what type R u guys were talking about. must be the old one, different shape to the RSX??
haven't been in the cars yur talking about cause they are just ""US. but i'll base it on the following.
friend has the new Honda Integra type R (rsx shape) the recaro's are just fine. tough car and would be my pic even though it's slightly heavier than the old one, and torque steer sucks.
g/f has mitsi FTO v6 mivec, it's a nice car, i imagine thats what your 3g eclipse is like. flatmate has a lancer GSR with the 4g63, they are a tough engine and lighter than the 6, plus had more development so reliability should be right up there and easier for parts, i don't think the new eclipse could match the integra.if yur RSX is detuned then i'd have to go with the celica! it's a little behind the type R over here but only just, so if you dropped any power it'd have it!
best japanese FWD.... EK Civic Type R, ran faster than the integra at the same time and i don't think the new civic type r beats it. very light and very mean.
Who needs AWD? i feel inspired by the original 911 turbo, my car will have more rubber sqeezed in its ass than Annabelle Chong! and it will go down as one of the greatest rides in history!
