Old 11-19-2004, 03:59 PM
Plastic_Fork's Avatar
Plastic_Fork Plastic_Fork is offline
Re: b16b
The B16A automatic transmission came on some Del Sol SiR's in Europe. Del Sol years in Europe were from '92-'98. Not entirely sure if they had the automatic B16A transmission in Japan (though it would seem reasonable), but I know they had them in Europe.
That should give you somewhat of a starting point.
1995 Honda CRX del Sol VTEC
Manufactured: Suzuka, Japan
Production Sequence #1269
Team Del Sol member #1131
HondaVision: Team Sol Forum - Home of Team Del Sol
Old 11-22-2004, 03:45 AM
eckoman_pdx's Avatar
eckoman_pdx eckoman_pdx is offline
Honda God
Send a message via AIM to eckoman_pdx Send a message via Yahoo to eckoman_pdx
There was a JDM Automatic B16A as well as a European one. As for a "d-sereis vtec head swap," you are refering to a "mini-me conversion, sticking a D16Z6 head on your non-vtec d-series block. You'll need the Vtec ecu from an auto tranny EX too. Or yuou could swap in an auto D16Z6 and ecu, your tranny should bolt up, as d-series trannies are pretty interchangable.
A JDM or Euro B16A is the easiest B-series auto swap you can perform. A B18B1 auto tranny swap IS possible. A LOT of work goes into it, I don't recommend it. The tranny is too big for the frame rail, the car isn't wired for the teg's electronically controled auto tranny. At any rate, if they know what they are getting into, the cost will be more than doing a swap and auto-manual conversion. It is FAR easier to do a auto-manual conversion and swap in a manual b-series than attempt that. If you really want and have to have an auto b-series, send the time and money to swap in a JDM B16A auto. A decent number of JDM Civic Ferio's (4-door sedans) came with the auto trannies.
BTW, GScivic7, the cheapest I know of labor for an auto-manual tranny swap being quoted for is $600 (of course not including the parts).
It's just that easy folks... mind the forum guidelines and we're cool.
Empty Pockets Racing Member #6
EPR Member 4 Life
Old 11-22-2004, 03:54 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: b16b
we were quoted $400. $400 for labor and $800 for parts. Too damn expensive. Might as sell the car, and spend $1200 more on a newer manual version and begin from there and that's just what he did.
Empty Pockets Racing Member #1
Old 11-22-2004, 04:38 AM
Honda God
Re: Re: b16b
It all depend on the situation. If you had a 93 civic HB with a nice custom Kandy Blue color, nice interior work, suspension and wheels. Selling it and buying a new one that's a manual could get damn expensive when trying to restore it to the same level. That paint job would cost more than the $1200 to convert it to a 5-speed for a GSR. Now by the same token, if this person lives in SoCal and has a stock Teal green 93HB auto, it's a different story. Those things grow on trees down there. By the same measure, if someone lives in an area where body rust is an issue due to salted roads, and the auto tranny is the best condtioned one they find by far, it may be far cheaper (and safer) to do the auto-to-5-speed swap than to buy a 5-speed civic with rust and fix that problem.
All things are not always the same across the board, and you want to be careful not to trade one problem for a bigger one. As with any major prroject, weighting your opinons and not jumping to conculsions is your best bet.
Also on a side note, I have run into places over the years that don't charge too much more to the overall price of a engine swap to do it if the customer is doing it at the same time as a swap.
EPR Member 4 Life
Old 11-23-2004, 07:17 PM
serv serv is offline
Re: Re: b16b
If you leave your car an auto the best you can do is a D-series VTEC motor. Either a D16Z6 or D16Y8. I'd go with a D16Z6 cause that will be just complete drop in and bolt on basically. Just have to wire it for VTEC with a VTEC ECU.
i am really considering the d16z6 swap. if i were to do that would i be able to use the turbo kits designed for that engine regardless of my auto transmission?
Old 11-24-2004, 01:47 AM
GScivic7's Avatar
Re: b16b
that would be correct.
Old 11-24-2004, 02:02 AM
right on
i think that's the route that i'm going to take....now to find a d16z6 with low mileage on it.
Old 11-24-2004, 02:44 AM
so i found a place that sells the z6 engines, http://redrumcustoms.com/pd_zc.cfm has anyone ever heard of or ordered from them before? what are the major drawbacks to having turbo and an automatic transmission?
Old 11-24-2004, 03:37 AM
GScivic7's Avatar
Re: b16b
the auto tranny can't handle much torque before shitting on you. You can always get it built by Level 10.
