Old 11-18-2004, 07:14 PM
94sportsedan 94sportsedan is offline
Well that's thef uel rail assembly, not the fuel lines, getting closer though.
Old 11-18-2004, 07:35 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Re: Quick disconnects o-rings fuel leak
Will try again tomorrow.
Old 11-19-2004, 11:05 AM
Checked every manual I have and called GM. They say they never heard of it. Find it hard to beleive GM hasn't .... Oh I forgot, we're talking about GM.
Good luck
Old 11-27-2004, 11:51 AM
SsHaDyGt SsHaDyGt is offline
I FOUND IT! at NAPA autoparts they sell the metal end fitting youll need that and a piece of 3/8 plastic piping they sell that 2 and bassically you cut the molded part of the line out and splice the new piece in use hot water on the piping not a heatgun the heatgun made things worse let me know if you need any help
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 11-27-2004, 03:00 PM
yes there are two o-rings on the line that goes from the metal fuel rail to the plastic line. They are inside the plastic line.
Old 11-27-2004, 06:44 PM
TIMOTHYHEMPLE TIMOTHYHEMPLE is offline
Had Same Problem With Mine 93 Grand Prix. Plulled Old Ring Matched It Up At Auto Parts Store Runs Like A Champ. Replace All Of Them If Possiable
Old 11-29-2004, 08:20 PM
How did you pull them out.I'm afriad they may crumble and fall into teh fuel line. Or nextfear would be how to cram the new ones in.
Old 11-29-2004, 11:47 PM
at NAPA they had the whole metal quick connet piece i replace the whole piece
Old 11-30-2004, 12:05 AM
if you don't mind posting their brand and part number that would be great!! The people in NAPA by me were telling me to go to dealer.
Thanks
Old 12-01-2004, 03:10 AM
O Rings
All I Did Is Pulled The O Rings With A 90 Degree Scrib, Found A Good One And Sized It At Napa, Replaced All Of Them And Cut An Access Patch In My Trunk To Gain Access In The Future Instead Of Pulling The Tank I Open My Access Cover
Old 12-01-2004, 03:12 AM
Ask Napa For Thier O Ring Box, Every Store I Have Ever Been To Has One, There Are Many To Choose From So Be Sure You Look Well
Old 12-01-2004, 03:13 AM
Standard Black O Rings Work Just Fine, Do Not Let Them Bull**** You
Old 02-20-2005, 09:25 AM
Oz-1FASTGTP Oz-1FASTGTP is offline
Lightbulb Re: Quick disconnects o-rings fuel leak
I'm trying this repair today
I got the o-rings at Advance Auto Parts
You need to buy two for the return line, and two for the feed line.
Oz
Originally Posted by 94sportsedan
One of my fuel lines is leaking gas right on the supercharger, Is there a way to replace the o-ring inside the metal coupler end of the plastic fuel line. I was hoping it was an o-ring on themetal line but this design has it in the fuel line. How do you get the o-ring out and does anyone have the part number for a replacement o-ring?
Old 02-20-2005, 09:26 AM
Re: Re: Quick disconnects o-rings fuel leak
You need to use VITON o-rings or the fuel will eat them up, sorry.
