Go Back   Automotive Forums .com Car Chat > Racing > Street Racing
Old 02-27-2002, 08:59 PM   #16
Self
Self's Avatar
Send a message via AIM to Self
Heyyyy....I thought 10 lbs was pretty good...Anyways, yeap, I had a header on the CUSTOM turbo. It was actually a type-o b/c I'm used to typing i/h/e...But in actuality, it could have applied to the car. What I actually did was steal a X-shorty header originally made for a chevy. Had it coated, flipped it upside-down, and had a short elbow of piping welded onto the end of the flange, then bolted the turbo to the end of that. Only reason I ever did this was because of extreme rusting on the original turbo manifold when I got the car. Since I was upgrading the turbo anyways, decided to go with a new manifold as well. Decided to try this out just to see if it could be done. Worked ok, I supposed, no leaks thanks to some great fabrication by my exhaust shop.
There's no replacement for displacement...No, not even a turbo.
Self is offline   Reply With Quote
Old 02-28-2002, 01:39 AM   #17
jOYRiDe
Originally posted by ldelaysionl
theres a bad mx3 ive seen in some magazines with a 20b transplant...
mx3 with rotor engines are becoming common in australia
just recently, mazda released mx3s with factory turbos (i think for the aussie market only) which are faster then s2000's
jOYRiDe is offline   Reply With Quote
Old 02-28-2002, 12:03 PM   #18
PFCfutrell
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
Originally posted by soul180
I had/have a 1988 plymouth sundance RS Turbo.,,,that bitch has 136hp, and can get second gear rubber...unlike my dx with i/h/e....how can you tune the turbo?
My mostly stock '91 CRX SI spins tires in second and barks them in third at the track, it's only 108hp + an intake.
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
PFCfutrell is offline   Reply With Quote
put a face to a name! post a pic ! cassidy COMPLETELY off-topic 86 08-25-2005 12:58 AM
After putting new faces on, gauges read funny... 91civichatch2571 '88 - '91 Civic | CRX | Wagon | Shuttlee 3 01-15-2004 07:27 AM
Plea for help, bring a smile to the face of a dying 16 yr old agh2 Car Shows 0 08-27-2003 07:39 AM
lets put faces to the names ShelbyGT Mustang Talk 0 09-11-2002 08:30 PM
How do you put in the Friken Smilie Faces? Porsche COMPLETELY off-topic 6 02-14-2001 06:17 PM
