| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
#16
Re: Adding a circuit that is hot during run only
I couldn't get in touch with him and yesterday at the Auto-X I had a sudden thought on this. The ignition has several positions:
Off ACC Run Start You're pretty knowledgable and know what these do. Would it be possible to find the trailing hot on the ACC and or Run position and run this to a relay? Just a thought |
#17
thats a idea, latching relay off the Start position.
or another idea i had, same as the alternator light idea i had before, but use the oil pressure sensor. |
#18
Oooh. this gets better every time!!
Dragging people kicking and screaming into the enlightenment. |
#19
I still say vacuum switch. www.graybar.com list 13 made by Square D alone. You can get normally open or closed. And the amout of vacuum required is adjustable. This way if the engine stalls for any reason it will detect this. These switches used to be common on electronic water injectors. This was the most sure way to know the engine is turning. YOu did not want the motor pumped full of water just because the key was "on".
![]() Yes, I am retarded. |
#20
I'm sold on it. Vacuum switch it is, with a relay or solenoid controlling 50 amps worth of circuit taken directly from the battery by some 4 ga. wire. Daddy like.
#21
Curtis, the vacuum switch will work, but what happens when you floor it?
#22
I visited the graybar site and there are so many available thresholds for vacuum switchingt that I can choose one on a 0-30mm range or even one on a very small millibar range. Even at WOT there is still vacuum; as much as 3 inches of it, so I'll just have to get a switch that will stay closed above those pressures.
#23
is that relative or absolute? you wouldn't want going thru the hills to be a problem.
#24
They're all relative. They are pressure differential like the old diaphragm spring switches, just electronic. There are absolute pressure switches, but again, I don't think that even 15,000 feet would make the difference. Even if it only drew 1" at sea level, at 15,000 ft, that 1" should translate to .92". I'll just make sure to get one that switches low enough.
#25
These work really well. We used to use them on "electronic" water injectors. We used water injectors to reduce detonation. This was so we could 87 octane in our high compression engines during daily driving. Drove thru the mountains of Tennessee enroute from Florida to Indiana without any problems. Good Luck.
#26
The oil pressure switch sounds like a better choice. I'm still not real clear on why you're doing this. Would you care to elaborate?
#27
Re: Re: Adding a circuit that is hot during run only
My 1966 Bonneville is a tow mule for me. It is currently gutted of its wiring, interior, engine, tranny, everything. A new wiring harness is going in and I'm adding power windows, locks, mirrors, DRLs, two amps for small speakers, A/C, and an air compressor for an air suspension. It already does plenty of work with trailer brakes, trailer lights, and other assorted goodies. The air compressor for the suspension is a biggie, as are the amps. The amps will take a total of about 30A and so will the compressor. Add to that a moderately high compression Caddy 500 engine to start and the battery being in the trunk, it sure would be nice to have at least the compressor and DRLs on this mystery circuit so its not competing with the starter and placing draw on the battery every time I turn the switch on. To answer your next question (which I can just feel coming , I know that GM switches don't send power to accessories during cranking, but I will be using a Bosch switch which does keep it hot during cranking. I also don't want the compressor to be running if I'm sitting in the car and just want to hear the stereo.One more reason I'm leaning toward the vacuum switch is because I only have one port in the caddy 500 for oil pressure, and its occupied by the sender for the gauge. I guess I could tee off of it, but its on the back of the block just above the tranny belhousing and its a tight fit in that area. I have probably six unused vacuum ports so it just made more sense that way... unless you know of a different oil pressure port on the caddy ???
#28
Curtis, Yup, makes sense that your situation does require some unique attention. (Sierra - I read the post, and as Curtis saw coming, the ignition does not feed the accessories during cranking. He had not mentioned using a different switch.) Just thinking out-loud here, but perhaps dual batteries - or an isolated 2nd,
#30
oops, mouse got crazy! anyway, ....may work for you. It seems unlikely that you would start the car with all your accessories going, the stereo cranked and the suspension running. I'm not familiar with the caddy engine, but may find a plugged oil passage near the filter. They have to drill a feed passage somewhere. It's your baby...I was just curious what the project was. One final thought is that you could run a normally-closed relay to feed your accessories, and us the trigger line to the starter to cause it to go open. Good luck on the car!
