Old 02-22-2002, 02:04 PM
wees87lx wees87lx is offline
Send a message via Yahoo to wees87lx
well
preping motor u mean upgrading fuel pump, get fuel pressure regulator? cause i really don't want to have to build the engine up inside. I'll use lower boost if i have to.
Old 02-22-2002, 05:59 PM
jeffie7 jeffie7 is offline
Send a message via ICQ to jeffie7 Send a message via AIM to jeffie7
Preping the motor being lower CR do some work on the crank new rods pistons maybe some head work
and yes fuelsystem too
as for as putting down 200WHP and running 13 maybe even 12s... um no
maybe if you have a fully striped down car
Im looking at pushing 250-280WHP out of my 2170LBS civic and Im hoping to hit mid to low 13s maybe have a 12sec car from a rolling start but if you do the math and run the #s 200BHP out of a very torqueless engine will not get you under 13s
plus I really don't think the D block will hold up long with 200BHP so you would need to prep the engine unless you want a quick car for a week or two
I think with turbo low 14s maybe..... maybe high 13s
did you guys see the SCCM Supercharger review 272BHP and it ran 14.4 yes hooking up was a big problem but I don't think over 1.5 secs worth to break into the high 12s mark and thats with 72 more BHP over the other setup
same goes for the Type R 1/4 mile test from the Ultimate street car challenge had 242WHP yet only made a 14.7 pass at the track yes once again not setup for drag but like I said before no more then 1.5 secs was lost
also 210BHP is what a Eclipes has stock "GST" it weighs 2900LBS
if at 2100LBS a civic with the same BHP yet less torque should run high 12s-low 13s that would make a stock GST Eclipes run 13.8 or less in stock form
money for power the B16-B18 would be the best way to go becuase if you want anything over 180BHP you will have to really build the motor up unless you wany a fully track car thats not streetable "atlest I would not trust it"
its your money and your car just do the reserch I've found alot of drag times online you can use to get an idea of what your car would run
check out
http://www.g-speed.com/pbh/fastest/turbo-only.html
it has a few listing
theres one Delsol SI running a JRSuperCharger with a 70 shot of NOS and hes running 12.5
every other civic running turbo is running 14.1 or slower
Old 02-23-2002, 01:54 AM
Brice Brice is offline
Send a message via AIM to Brice
Bust your ass and do both
Old 02-23-2002, 09:19 AM
fjt fjt is offline
Actually your 9:1 compression should be good for boost but lower compression= more boost.
I would leave it like that for now and just invest on a better fuel system and if you can some reinforcing on the engine.
Theres a guy around here (VTC Civic) that has a Turbo EX runing at about 8 PSI on completelly stock internals, just a better fuel system.He's been runing the turbo for about 8 months or more and no single damage whatsoever to his engine.I think he puts around 194hp to the ground with his set up.
Old 02-23-2002, 12:33 PM
madtownhonda's Avatar
madtownhonda madtownhonda is offline
Send a message via AIM to madtownhonda
check out
the d-series motors are just as strong as the b-series motors.....there are plenty of guys running 10lbs daily, 12lbs at the track (stock bottom end, good fuel management)....the CX only weighs 2100lbs....I've seen hatchbacks with an ITR swap hit 12.9....you should be able to hit at least low 13s in a CX with 200whp
96 EX DOHC VTEC
Old 02-23-2002, 01:32 PM
in that case my 2170LBS civic by summer time should have 250-280WHP
after going on a little diet Im hoping to knock 70LBS off "anytips guys?" anywho it should set me well in the 12s at the track even tho I really don't think it will but hey if I keep thinking 13s and hit 12s I wont mind at all plus theres no let down =)
Old 01-04-2006, 07:03 PM
93CivicSiD16HB 93CivicSiD16HB is offline
Send a message via AIM to 93CivicSiD16HB
Yeah, I've been to the track many times and have seen EG civics run low 12's over and over, you just have to have knowledge time and money, though this way will save more money than doing a swap. You can already be going fast at the price to swap in a new engine. Besides at least this way you can always learn and in the chance of a detonation, do the swap or do the d16 up again!
Old 01-04-2006, 07:08 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: Turbo the D16z6 or drop in B16A?
Please look at the thread dates, this thread is almost 4 years old.
Old 01-04-2006, 07:15 PM
ok show me some posts on the d16z6 that have been posten after 2004, all the info i get anymore is swap out your engine, and sites like turbod16 for some reason have the forum locked so i cant even post
Old 01-04-2006, 08:09 PM
Re: Re: Turbo the D16z6 or drop in B16A?
WOW talk about old holy crap I just got an e-mail saying someone replyed to the thread. =)
Since then I insalled a built B16, (from bottom to top) about a year later I sold the car and it now makes with the current owner 570WHP on race gas and 430WHP on pump gas.
wow time does wonders.
oh and it went 10.6 =)
Old 01-04-2006, 08:11 PM
CivicSpoon's Avatar
There is no Spoon
The point was that you didn't even ask a question, that would be a little more understandable. I don't see why they'd have the forums locked, maybe it's a trial thing when you first sign up (to make you read and search before even consider posting a question). I'll post in your thread, so I don't continue jacking this one; I've got some info for you...
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 06:32 AM
