#16
Re: Gas pedal hard to push
Did you try to unstick is any spray TB cleaner around it to clean it up?
1995 Factory Blazer Service Manual for sale, PM if interested. |
#17
well i went and actually took off the throttle body and i found that it is not the butterfly. One of the plates is warped and it is binding which is keeping the throttle open. Im just gonna go down to the wrecker and pull a body to replace it.
#18
dang, how'd you warp it?
#20
Re: Re: Gas pedal hard to push
#21
believe me ive got the thing out and im looking right at the plate and its bent and rubbing against the wall inside the throttle body. Dont know how it happened...but im just gonna go grab another body for 25 bucks...problem solved.
#22
We need photos of this.
#23
Well after reading this thread I decided to try cleaning mine again. This time I bought STP Throttle Body and Air Intake Cleaner...it worked ten times better than the rubbing alcohol and toothbrush I used the first time. You don't even have to scrub it you just spray it clean.
Mine is now working great and doesn't stick at all. ****EDIT**** Forgot to mention, it smoothed out the idle too. Last edited by blazee; 01-19-2005 at 07:15 AM. |
#24
I would also like to see the pics of your "warped" plate.
#25
id like to show ya....but i dont have a digi cam to upload with...sorry
#26
ok i have a different question. I went down to the wrecker to pick up a throttle body and they have lots of them but none with the vacuum outlet that goes to the air cleaner assembly like mine does. if i use one of these and disconnect that vacuum line it shouldnt matter right??
#27
Hey guys,
I must say that that plate can be warped and cause problems like it did in mine, i started a thread about this, here is the link: http://www.automotiveforums.com/vbul...d.php?t=301242 I am still not sure why this happened, I belive I still have the warped plate sitting around somewhere once i find it i will take pics and post them for all to see, And i hate to say it but the IAC had nothing to do with it, my problem was because of this warped plate, savage8190 if you just open the throtle body and remove the warped plate your vehicle will once again be drivable, Oh and ever since i got rid this plate the engine revs up faster, not sure why but it works for now
2001 GMC Jimmy SLS 2-door Manual Trans 2wd 120K miles and still going - (Not Anymore, ABS screwed me and at 70 mph locked the front wheels and caused me to roll it and it sits in my garage now ) members.cardomain.com/vemucla2007 Ford F150 supercab lariat 2wd |
#28
just to let everyone know i changed the body and everything works great now
#29
Awesome, will remeber this for next time someone else has this problem.
#30
I sprayed carb cleaner down the intake while another person reved it up to 1500-2000 rpm
That freed up my pedal. I might do it at every oil change also. |
