#16
Re: 10,000+rpm
ca wiring is the same as the sr.
See ya.... |
#17
Re: 10,000+rpm
Imagine what a (100?)mm stroke would be moving at at 9K F1 piston speed isnt really all that special now-in-days the F20 at 9000, QR25 at 6800RPM, and the 13B all have piston speeds that rival F1 cars. Piston acceleration on the other hand... |
#18
Re: 10,000+rpm
ive never heard of a sr20 or a ka24 @ 10k rpms, maybe if the car has a shorter displacement.
#19
Re: 10,000+rpm
sr20det, 6500 more then enough. i dont even pass that. 10000rpm is not that usefull on a N/A mp motor i think.
"A good driver is measured not by his lap times, but by the amount of time he spend trying to make sense of his car" E.K. |
#20
Re: 10,000+rpm
well it is not going to be na, not a big fan of that, force induction is the way to go ( i think) I will prolly pimp out the ka. For the 2000 i ll spend on sr20 ill just build the motor and do upgrades to the head.
VR6> Anything FWD sucks for understeer? Swaybars do magic. |
#21
Re: 10,000+rpm
when did 13b's get pistons? There are a few 10k rpm srs search the net there is a hks sr20det that can do over 11k rpms.
There are tons of high rpm NA motors... CART, INDY, F1 they all used to have non-FI engines. EVER heard of a motorcycle? Almost 200hp with over 13k rpms on tap NA.... Or the 1/2 Million dollar superbikes with over 280hp with 14-15k rpm redlines. With a better HP/Liter ratio than most race cars.
IF I AM TYPING IN CAPS (LIKE NOW) I AM SORRY BECAUSE I AM AT WORK (DATA ENTRY) AND I HAVE NO CAPS LOCK BUTTON AND NO WAY TO CHANGE MY UPPER CASE LETTERING. SORRY! EMAIL CONTACT: [email protected] |
#22
Re: Re: 10,000+rpm
Gotta love how low the torque comes on though...with the stock setup + mmi you can get rubber in third with 17x7 sport tires...top speed of 140 which is only drag limited...rev-limited to about 164...and it's very smoothe at 130+...
Re: 10,000+rpm
If you want to rev a relatively standard motor with mild modifications then buy a honda motor or a rotary. If you want to rev to 15,000 + rpm then buy any motor that can flow that volume of air and build it to be able to do those sort of revs.. remember to consider the motor you choose in the beginning and to check that its enginereering charecteristics represent properties such as better valve angles etc before you upgrade to 3rd party components. (you will then get better bang for buck).. ps to the noob that posted "when did rotorys get pistons?"... well in case you havent noticed a rotory is an internal combustion engine and it has a rotor, which is a piston. anyway cheers.
#24
Re: 10,000+rpm
This thread is four and a half years old.
-Cory 1992 Nissan 240sx KA24DE-Turbo: The Showcar Stock internals. Daily driven. 12.6@122mph 496whp/436wtq at 25psi |
