Old 10-01-2004, 08:02 PM
skipr skipr is offline
Re: Re: I can't figure this %@#Z'n silverado out.
Originally Posted by brokesilverado
thank you I sent you a private message with my email on it
oh i didn't know about private messages. I sent reply same way. check your private message and get back to me
Old 10-04-2004, 05:21 AM
RPSTELMA RPSTELMA is offline
Do you need to set your timming?
Old 10-04-2004, 06:41 AM
brokesilverado's Avatar
brokesilverado brokesilverado is offline
yes i do i tried this weeked but i guess i need to use a scan tool i will be try'n to so that later on today.
Old 10-06-2004, 07:24 AM
still working on solving this problem hope to have an up date in a day or two.
Old 11-23-2004, 09:23 PM
96C1500 96C1500 is offline
Hopefully you figured things out by now. If you haven't I had the same problem. I had some work done and when I got my 96 C1500 back it had the error code. Alldata had the supplement for the P1345 code that was not in the service manual. I then bought a scanner that could read the cam retard offset. The value needs to be 0 +/-2 at 1000rpm. Once that was set I have not gotten the error code since.
Old 11-24-2004, 06:59 AM
thanks I will look into that I think I will have to pull the distributer and re set everything.
Old 01-27-2005, 07:42 AM
still have not had time o turn the light off on this truck i am going to get back to it as soon as it warms up and i can find a place to rent a scan tool.
Old 04-24-2005, 08:23 AM
bracketshark bracketshark is offline
did you get it fixed? what fixed it?
