Old 09-23-2004, 12:03 PM
djmavis djmavis is offline
well yes, i mentioned that I was told that that was a possibility. the mechanic wrote that off and said that that didnt make sence because the noise went away with the clutch in. I asked if it could just be when the driveshaft and u-joints are under load, and he said, "no."
Old 09-23-2004, 01:00 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Chirping noise from rear
get a second opinion.
Sounds like that guy didn't even try and defaulted to the most expensive job.
Go to a different garage and get another opinion.
Old 09-23-2004, 08:19 PM
busa_4 busa_4 is offline
do you mean the throw out bearing on the flywheel?
Old 09-23-2004, 09:12 PM
Mikado14 Mikado14 is offline
Yes he does mean the throw out bearing. And if it were bad you would hear it WHEN you pushed the clutch in. When the clutch is out, it "ain't doin' nothin'"
U joints can be noisy under load yes, yes, yes. It can and sometimes is the first way of knowing they are bad. When you hear banging, you better stop!
Old 09-23-2004, 09:16 PM
BlazerLT's Avatar
AF -Advisor
Yea, just get them greased or replaced.
Old 09-28-2004, 07:12 PM
wilfie27 wilfie27 is offline
Your throwout bearing going out will likely only cause you to have trouble shifting, and it is usually engaged when you have the clutch depressed so it should squeak then. Blazer LT is probably correct on the U-joint. It will correlate with wheel speed, the throwout bearing will correlate with engine speed. It will whine when there is torque applied to it. Changing it is not really that hard. 4 bolts hold the U-joint onto the yoke at the diffential and it will slide out of the transmission ( a drip pan is a good idea ) I changed mine last year and only found that there is a plastic ring injected into the yoke. The best way to remove the caps of the u-joint is to heat the yokes ( propane is probably best but I just let mine sit in the sun ) then drive the caps towards the inside with a socket and hammer ( you're throwing them away anyway ). The new ones will come with e-clips that will hold them in.
Old 09-28-2004, 08:36 PM
bigblackone bigblackone is offline
anytime a repair person tells you to live with something until it stops the vehicle ... thats a clue ... run to another shop.
and find one that will check the driveshaft and u joints
Old 09-28-2004, 09:40 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: Chirping noise from rear
^^^Smart man.
Old 09-29-2004, 10:18 AM
grayblaze grayblaze is offline
the mechanic should have been saying the pilot bearing not the throwout bearing. Pilot bearings will make a noise at lower RPM and fade away. However a $3 bearing would not be justified to drop the trans and clutch until at such time you replace it as well. I have never had ujoints chirp before but it is worth the try. Good Luck
Old 10-05-2004, 11:58 AM
Angry
hmm...ok so I greased up the u-joints and everything...and the problem persists.
I had a buddy stick his head out the window to help me listen to the noise, and so I could concentrate on driving. The noise seems to be correlated more with engine speed in his opinion (I had originally said it was whell speed, but I guess I may have been mistaken). It goes away, as I mentioned before, when the clutch is in...and ALSO above a certain RPM. I dont know exactly what this RPM is because I dont have a tach, but it is whatever the engine is at when im going about 13 mph in 2nd gear.
The noise has gotten just a little bit louder, and i am starting to be able to hear it in 3rd gear.
Any other ideas? I am sorry to be a pain about this, but money is a bit tight and I cant afford to blow it on the wrong repair!
Old 10-05-2004, 03:47 PM
it sounds like it is your throwout bearing. throwout bearings will make noise when not in use and the noise will go away when the clutch pedal is pressed. pilot bearings will make noise all the time reguardless if the clutch pedal is pressed or not. unfortunetly you will have to remove the trans to fix the problem anyway. you say your tight on money but i do not recommend replaced just the noisy part as other parts will make noise on you eventually. if you are going to do this replaced the clutch disc, pressure plate, resurface flywheel (if necessary), pilot bearing, throw-out bearing. thats alot of work just to replace a bearing. if you dont have the funds then dont do it be3cause your going to be pissed if you replace 1 part and another goes bad. good luck!
Old 10-05-2004, 10:12 PM
BlazerLT's Avatar
AF -Advisor
So with the clutch engaged and you are normally driving you hear nothing?
Old 10-07-2004, 10:07 AM
Fireplug Fireplug is offline
No such thing as a throttle bearing. I think you meant a throwout bearing on the clutch.
Put the trans in neutral and push the clutch pedal in and out any noise change ???
While driving the noise only happens while the truck is moving and not sitting at a stop??
If ti happens only while moving its the u-joints OR the rear end pinion bearing but I would bet on u-joints VERY common problem
That it to a shop to do that work. They can be a real pain in the but to fix if you do not have the right tools
Fireplug
Old 10-07-2004, 10:09 AM
Ok i found a trans shop that did free diagnosis. They said it is likely the pilot bearing, but it does not sound too serious yet. The mechanic said just to wait until it gets really loud or the clutch needs to be replaced. Both shops I took it to have told me the same thing now.
Blazer, to answer your question, the noise only occurs at low speeds with the clutch released. If i push in the clutch, or just after I have reached a certain engine speed, it stops.
Thanks again for all your help!
oh, p.s. I am pretty sure this is unrelated, but does anyone else notice that after being on the freeway for a while the clutch is much stiffer for a little while? Is that normal?
Old 10-07-2004, 10:11 AM
A
pilot bearing will be a constant noise a throwout bearing will change with the clutch movement.
Fireplug
