Old 09-17-2004, 02:48 AM
Shpyder's Avatar
Shpyder Shpyder is offline
Moderate moderator
Re: What spark plugs to use
change your plugs at every oil change? Isnt that overkill?
The daily driver. The weekend cruiser. The lazy shop hog.
Old 09-17-2004, 10:22 PM
RSLaser RSLaser is offline
Posted by coolguycooz - 09-16-2004 at 11:13 PM
Also i heared that single tip is still the best those multi tip and tripple and the new 4 tip spark plugs all suck is this true?
The current will take the shortest path, single tip only goes one place...the platinum series plugs with the 4 tips, only sparks to ONE tip at a time...not all 4. Id say its better to go ahead with single tip...unless your engine is fuqed and you get alot of carbon buildup(which is bad).
1991 Plymouth Laser RS
Only sat for a few years....
Old 09-17-2004, 10:30 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: Re: What spark plugs to use
Ehh.. it takes me ~6 months to get to 3k miles. Even if it is overkill, o well, they cost like $6 for 4 plugs.
For Sale 98 Eclipse GS, 5 spd
Old 09-17-2004, 10:58 PM
kjewer1 kjewer1 is offline
AF - Advisor
Turbo motors eat plugs, you cant replace them too often. At least pull them out for inspection and regapping at every oil change.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 09-17-2004, 11:38 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
I've got the NGK-R's in and they run pretty good!! Today I stopped to try to find the BPR7ES plugs and they were a special order... I was conned into getting the denso iridiums... under light load I feel the difference but when I boost at like 8+ psi it starts to sputter like its missing...car shutters.
They are gapped at .039-.040 what gives? Should I gap them different?
I've heard and have been told that iridiums are the shiznit...
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-18-2004, 01:40 AM
AF - Advisor
I posted in the other thread about this.
Kevin Jewer
Old 09-18-2004, 05:29 AM
BlackSpyder1998 BlackSpyder1998 is offline
hey guys you say to use BPR6ES and I went to http://www.ngksparkplugs.com/apps/ca...uv/results.asp and it say it takes BPR6EKN and i wanted to know which ones to get for a 98 GST spyder I only have exhaust and intake if that matters and also what is the gap that i gapped them too
Old 09-18-2004, 11:07 AM
AF - Advisor
I think the 2Gs came stock with the 4 electrode (or 2) NGKs. Just use the stock plugs for a 1g, should be bpr6es.
Kevin Jewer
Old 02-06-2005, 09:39 PM
Livid's Avatar
Livid Livid is offline
i was really happy with my 4 tip ... i just switched over to single and i notice a big drop in HP :/
1995 EAGLE TALON ESI
Eclipse Conversion Kit/Bomex Side Skirts/BMX Rear/Blitz Front
17" Rims/Yokohama Tires
Pearl White Paint
CF Hood/CF Tail Lights/Headlights
Aftermarket Spoiler
Cat Back Exhaust
50 hp Shot Nitrous/Side purge system
Aftermarket 12psi Stage 3 Turbo
Cold Air Intake/Greddy Intercooler
S3 Racing Chip
Front/Rear Strut Bars
Short Shifter/Racing Clutch
APC Racing Seats
Navy Blue Carpet
Dual Guages/Custom Paint
Alpine/C7 Sound System 3 12" subs in custom trunk box
Old 02-07-2005, 03:18 AM
AF - Advisor
Non turbo is different. But I still find it unlikely. Odds are the gap is not the same.
Kevin Jewer
Old 02-07-2005, 12:36 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Most spark plug favor going to NGK is about the turbos, like Kevin said. How exactly did you 'notice' a drop in HP? Felt like it?
Old 02-07-2005, 12:41 PM
Livid's Avatar
Ya i could totaly notice less pull when i floored the car.. Shifting from 2nd to 3rd, then redlining in 3rd I could tell a big difference in the acceleration. A very NOTICABLE one... I just got a set of NGK iX Iridium's , a MSD coil Pack, and magnecore plug wires, ill see if i notice a difference
Pearl White Paint
Aftermarket Spoiler
Cat Back Exhaust
S3 Racing Chip
APC Racing Seats
Navy Blue Carpet
Old 02-07-2005, 02:21 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Kris
2012 Genesis Coupe 2.0t
Old 02-07-2005, 02:54 PM
GTPSPEED GTPSPEED is offline
BOSTONjoe98gs
It seems that, like many issues, there are two camps regarding Bosch Platinum Plugs.
One set of people says they work great and cleared up a lot of hard to fix problems, idling, etc.
The other set of people point to all the incidents of mangled plugs and indicate no noticeable improvement when they used them.
It seems that the problem cases have generally been with high performance engines, and the 'works great' group tend to be on, um, 'less aggressive' engine/driver combinations. (?)
I recall seeing that Bosch platinums were supposed to operate at a lower voltage. If that fixed a problem, then perhaps there was something else wrong with the ignition system, perhaps wires, and perhaps fixing the other problem would allow 'normal'/other plugs to work just fine. Performance engines tend to be more cared for and perhaps don't get to the point where low voltage plugs would show any sort of improvement. In fact, they tend to need higher spark voltages, so...
Performance engines tend to work harder, and perhaps the Bosch Platinums aren't up for the additional stress. But if you don't stress the engine, e.g. no turbo, no WOT to redline, etc., perhaps they work fine, or better for non-aggressive driving.
I'm hoping that explains the discrepancy, and that we can put this controversy over Bosch Platinum plugs behind us.
Incidentally, Bosch also makes the 'Super' tri-electrode plug. This would seem to counter the ability to index the plugs, so perhaps we see another example of Bosch plugs not designed for the performance market.
2000 GRAND PRIX GTP RED 14.345 @97.8mph
ubend delete
3in jimmyC downpipe
magnaflow high flow cat
Joeflo CIA (made it myself)
free bypass mod
3.4 pulley from zzp
Gates premium belt
1 step colder plugs
zzp PCM
ss 409 xl turbo mufflers
Old 02-07-2005, 04:19 PM
I have used the bosch 4 before in a NA car and they were great....
I know some people that have tried iridiums and it's about 50/50 as for better and worse.
All engines are different to an extent and will require diff plugs.
I took the majority advice and went with the NGK BPR7ES plugs and I won't put anything else in my spyder from now on.
I put my iridium plugs on ebay to get rid of them..... I should have went back to the autozone and shoved them down that Csuckers throat but shame on me for believing some schmuck!!!!! Oh well.
