#16
Re: Throttle stick in between shifts please help
well, when you pull it off, it might be half open.. It all depends on how much you have to turn it to set it correctly.. But as soon as you pull it off it should spring back.. and any time you push it, it should spring back.. If not, it probably needs to be replaced..
If it isnt closing properly, then itl hold your throttle open too
1991 Camaro Z28 |
#17
would you suggest greasing it and putting it back together and trying it again or just replacing it?
#18
BTW.. was your engine light coming on?
1991 Camaro Z28 |
#19
its probably damaged inside and will need to be replaced..
1991 Camaro Z28 |
#20
Wait a second... I just realized that I think you took out the wrong part..
1991 Camaro Z28 |
#21
shit.. sorry man.. I shoulda caught that right away, but I think you have the IAC valve
1991 Camaro Z28 |
#22
![]() That isnt off of a camaro.. But the TPS on your car should be very similar
1991 Camaro Z28 |
#23
yea sry i got kicked off. i ermoved the black circular thing with spring loaded thing inside is that the iac?
#24
its on the passengerside of your throttle body
Well the IAC and the TPS are both spring loaded..
The IAC shaft travels in and out, the TPS travels in a circular motion..
1991 Camaro Z28 |
#26
ok so i got the iac. i took it off, readjusted it, put it back on and tried to start my car and it wouldnt start so opened the spring a little more and my car started so im assuming this whole problem is caused by the iac that i just got replaced
#27
Your ECM will open and close that as neccasary.. If you could move it in and out, it should be OK!
I still think its vacumn leak or bad TPS
1991 Camaro Z28 |
#28
aight thanks man im gonna go back to my buddy's shop and have him fix it thanks for your help i appreciate it
#29
good luck
1991 Camaro Z28 |
