Old 10-27-2004, 09:41 PM
nlghtcrawler nlghtcrawler is offline
Send a message via AIM to nlghtcrawler Send a message via MSN to nlghtcrawler Send a message via Yahoo to nlghtcrawler
Re: Several problems with 95 Camaro, HELP!
Originally Posted by johnz28
...but I hate seeing my babe with a light on.. as well as most of you for sure
why is that?... i have a few ideas but i dont wanna be rude
Old 10-27-2004, 09:42 PM
cuda_dude cuda_dude is offline
Will Whore For Car Parts
Send a message via AIM to cuda_dude
hahaha..... bag it and shag it
1995 Camaro - Z28 - M6 - Hardtop
2007 GMC Sierra 2500HD SLT Classic
-R.I.P. Andy (Hypsi)-
Old 10-27-2004, 09:45 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
behave guys, new lady on campus, might not appriciate our humor.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 10-27-2004, 09:46 PM
sorry, just one of those thats to hard to pass up
Old 10-27-2004, 09:51 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
hahahaha
Old 11-02-2004, 08:44 AM
Bridget Bridget is offline
Phillip, I was told to check the canister for cracks for air loss or check the vacuum hoses that run near the battery. Battery acid may have leaked onto them and made them crumble. Neither was my case and I still have the problem.
Old 11-02-2004, 08:53 AM
89IROC&RS,
Thanks for the gentleman comment, I'm pretty use to the tit-for-tat comments. Gotta get em in when you can.
I hope that is not the problem with my air, but everthing else has been checked, except that. Thanks for the advice and I really appreciate the door info.
Could the bogging down have anything to do with the rear end? I had it replaced a couple of years ago and someone said that it may have the wrong gear ratio (I don't know what that really means). When I am going up an incline it really boggs and if it's very steep I have a clunk when I finally reach the top. Not always a clunk but most of the time. Actually, I can be driving at a steady slow speed and if I let off the gas it will also make that clunk. Any advice is appreciated.
Old 11-02-2004, 09:02 AM
cuda dude,
I still have the EGR light on. They went in and cleaned the ports but that did not solve the problem. Sorry, I just don't know. I do have a mechanic friend of mine who will be working at solving some of these little issues (appreciate the advice from 89IROC&RS on the door). He hasn't looked at it yet or driven it, he just told me to bring it by on his off time and he would see what he could do with it. If he can clear any of this up I will be sure to post some of his findings. Thanks guys.
Old 11-02-2004, 01:01 PM
89IROC&RS's Avatar
first off, your quite welcome
with your rear end its possible it wasnt set up proporly, if the gears are incorrectly spaced, they can theoriticly bind together under some situations, making them harder to turn, and thus causing your bog, and then come apart when load is releaced causing the clunk sound. im just shooting in the dark here, but it is a possiblity, i dont think a swap in gear ratios would cause this, just improporly installed gears.
Old 11-04-2004, 07:09 PM
Thanks again, this H-E-L-P-S big time.
Old 11-04-2004, 10:00 PM
89IROC&RS's Avatar
anytime
Old 11-06-2004, 01:50 PM
92rs25th's Avatar
92rs25th 92rs25th is offline
Send a message via MSN to 92rs25th
If you have a used EGR valve , Maybe just clean the POS out. Or just eliminate the EGR system all together. Dunno if you'd pass emissions then. You 'could' get a hinge shim to finx the door temporarily , Usually last about a year or so , More or less depending on how much you open and close it. It's a lot cheaper and easier to do that pull the brackets out and re-weld them. Also , The door , when it flung open from high speed winds or whatever , Might have tore or stretched the metal around the mounting bolts , causing a teter in it maybe. I dunno , I'm stuck on my 92' . Rear end gears as he says , Just sounds like they were improperly installed. A/c system , what was previously posted sounds about accurate. Hope some of us can help you and save a little money for you =)
I love rice so much , I eat it daily. Yum yum Civic.
1992 RS Camaro 383.
2004 Mazda 6.
2003 Subaru Legacy GT Limited.
1984 Nissan 300 ZX
1993 Mazda MX-3 ( Newest addition to my collection. )
http://photobucket.com/albums/y187/ohjiro
Old 02-02-2005, 08:01 PM
Re: Re: Several problems with 95 Camaro, HELP!
Originally Posted by jpmurphyslaw
Did you ever find the solution to your Camaro problems regarding the air vents? My camaro is beginning to experience a similar problem.
thanks,
Philip
Phillip,
Sorry, I never have found the problem to the vents. I wanted to check in with you and see if maybe you have a possibility on the problem. Appreciate any info.
