Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 09-20-2003, 07:46 PM
lowders lowders is offline
Smile Programming G20 Keyless entry remote
I read the instructions in this forum for the programming of the keyless entry. We tried it about 10 times and were unsuccessful. We called the Nissan dealer and the instructions he gave us worked on the first try!!
1) Get in the car, close the doors
2) Lock the doors using the automatic lock
3) Put the ignition key in/out of the ignition until the hazard lights flash (6 times for us)
4) Turn the key to acessory
5) Push the Lock button on the remote
6) Unlock/Lock the doors with the automatic lock*
7) Turn the key off
8) Open/close the doors.
We were programming 2 remotes at the same time, since the previous programming attempts "deprogrammed" the remote that did work, so if you are doing 2, after step # 6 you push the lock button on remote # 2 then continue to the end.
Hope this helps.
Old 12-13-2004, 11:25 PM
blue4917 blue4917 is offline
Send a message via Yahoo to blue4917
Re: Re-Programing Stock Remotes
Originally Posted by L3thalg20boy
Someone please tell me those instructions arent really true?
try sliding it in and out 10 times within 10 seconds
Old 01-31-2005, 08:56 PM
key fob code?
hi on my 2 fobs that i purchased it has the code type-CRZ032 MY CAR IS 1994 PRIMERA Egt with leathers
Old 06-23-2005, 04:40 PM
kimberlynn kimberlynn is offline
Re: Re: KEYLESS REMOTE PROGRAMMING INSTRUCTIONS
hi im looking for a key fob for a 1994 infiniti g20
dealers are crazy they want 155.00(this is just the remote)
i wa hoping you may have other resources
also the numbers you listed on the back of the remote for a 95 g20 would they be the same for a 94?
Old 06-23-2005, 07:11 PM
Smile Re: g20 - 95 keyless remote programming
hi im looking for a key fob for a 1994 infiniti g20 ,leather seats
if anyone could respond with any info i would really appreciate it
thanks alot
Old 11-05-2005, 06:17 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
The numbers are the same for a couple years of the G20. Check my signature for the G20 remote:
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 11-18-2005, 01:24 PM
ettt6 ettt6 is offline
I am havin probwlma programmin the remote. The serial number is about the same A269ZJA073.
I have tried the directions above and tried waiting for the hazard lights to appear on, but thats not working for me either. Ive probably tried both methods listed in this post about 20 times. I am at a loss and would love a little advice.
I dont know anything about the model of my car other than the basic g20 infiniti 1996. When I bought the car it didnt have a manual with it. Also i have factory leather seats.
Old 04-12-2010, 07:43 PM
DaleEarnhardt#3 DaleEarnhardt#3 is offline
Still having trouble???
I tried and this worked for me. I'm not completely sure how, as it worked somewhat differently as when I programmed it last time, but here's my advice:
1. Get into the car and close the door, unlocking the driver's side door.
2. Pop the trunk using the button on the driver's side door panel.
3. Lock the doors using the auto-lock (on the console by the windows).
4. Take the key in and key out rapidly ~20 times (for me, the warning lights did not flash, but it still worked.
5. Turn the key to the '2 ACC', or accessory position.
6. Push the lock button on the remote you are trying to program.
7. Unlock/lock the door with the auto-lock mentioned in step 3.
8. Turn the key off, and then remove it from the ignition.
9. Open/close the doors.
10. Test your remote.
11. If this doesn't work, try using the remote before opening the door.
12. If this still hasn't worked, try opening the hood, going on the passenger side of the car, and opening the into black box (with relay plugs/switches). Here, remove the 'Horn' plug and replace it before attempting to try again.
***It took me three attempts, so I don't know exactly how the process worked and/or if any of the steps made a significant difference, but these are definitely some things to try as I eventually had my device working properly.
Old 05-01-2010, 06:55 PM
Onblsht's Avatar
Authorized Vendor
Its always the SPEED of the key insert/remove process that seems to give people difficulty with the programming process.
If you are doing it slowly - try speeding up.
If you are doing it really fast - try slowing down.
Different Nissan/Infiniti vehicles seem to respond to different times for this part of the instructions, so just adjust your speed and you will be successful in getting the vehicle to respond.
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 3 12-15-2010 11:29 PM
2007 Honda Odyssey Keyless Remote Programming 2009mustang Odyssey 1 08-25-2010 05:06 PM
Program 2007 camry keyless remote marty.graw Camry/Camry Hybrid/Vista 1 03-31-2010 08:13 AM
How to put BCM into program mode? (Where is BCM/MALL fuse?) copchick527 Grand AM 5 03-02-2009 03:30 PM
chime indicating keyless remote error - 2003 Pontiac Grand Am Jcolli06 Grand AM 1 02-18-2009 06:37 PM
