Old 08-23-2004, 02:20 PM
ashah000's Avatar
ashah000 ashah000 is offline
Send a message via AIM to ashah000
Re: amp not workin
Are your RCAs and power wire on the same side?
Check your ground, make sure it is tight
For Sale 98 Eclipse GS, 5 spd
Old 08-23-2004, 05:11 PM
ScorTmobileR ScorTmobileR is offline
Send a message via AIM to ScorTmobileR
you mean the same side of the amp?
i got it all goin now,i played withthesetting on the amp andgot the crackiling to stop. but only the leftsideis working, no theright. ive tryed everything ican think of, when i attached the speakers back tothe head unit ( so they were not attached tothe amp at all) then they worked, so somewhere between the amp and the speakers theres a prob, but its notin the stock wiring.
Old 08-23-2004, 06:47 PM
ashah000's Avatar
Re: amp not workin
No I meant that did you run the power wire and the rca's on the same side of the car
Old 08-23-2004, 07:28 PM
they are both goin down the center console, do they interfere with each other or sumthin? cuz its bugginout or sumthin. im about to just light it all on fire or sumthin. it keeps turnin off and on.
Old 08-23-2004, 07:47 PM
Navy I.C.'s Avatar
Navy I.C. Navy I.C. is offline
Re: amp not workin
how were your speakers connected to your amp?
were they soldered, crimped on terminal lugs, bare wire, etc.?
THE DARKNESS!!!
an African Soup Bone Production...
Old 08-23-2004, 07:57 PM
Re: amp not workin
crimped termianl plugs
Old 08-23-2004, 08:08 PM
Navy I.C.'s Avatar
Re: amp not workin
a common problem I see alot is when somebody crimps the lugs on so tight they cut thru most if not all of the conductors, that might be something to double check
THE DARKNESS!!!
Old 08-23-2004, 09:12 PM
ok ill check that thanks
Old 08-24-2004, 03:14 PM
yea that wasnt it i redid them but its wire now, i didnt have any more crimps. i still cant figure it out
Old 08-25-2004, 08:11 PM
Navy I.C.'s Avatar
Re: amp not workin
are you sure there was no power avail. on your steady hot, because if you short it to ground while the amp is grounded, 9 times out of 10 that's pretty much a wrap for your amp...try getting a local shop to bench test it for you, they'll do it for a couple of bucks, (about $5 - $10) for their time
THE DARKNESS!!!
Old 08-25-2004, 11:13 PM
I Have No Idea What Youjust Said
Old 08-25-2004, 11:35 PM
Navy I.C.'s Avatar
Re: amp not workin
If you short circuit a hot, (live) wire to the chassis ground of your system, and your components are chassis grounded, that would be the same thing as shorting a hot wire directly onto the chassis of your components...a local shop can put your amp on a test panel to troubleshoot all of it's functions
THE DARKNESS!!!
Old 08-27-2004, 12:20 PM
thanks buddy
